'90 Trooper V6 starter swap q? #777949 01/07/07 04:57 AM
Hooplehead Offline OP
Do I remove starter from under rig.. and can I get to the
wires from the top or bottom?
*I'm off work with a screwed up back.. so I'm thinking
of cutting the inner firewall/fender for access like a
hillbilly Hooplehead would do..
Currently, it just "clicks" with new battery and clean
wire leads.. Truck starts fine with push or pull down the road, though a bit high idle for some wierd reason...
Advise? <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: '90 Trooper V6 starter swap q? [Re: Hooplehead] #777950 01/07/07 05:11 AM
Richard Saylor Offline
Disconnect the battery. Go underneath and unbolt the starter. IIRC, they're 15mm bolts. Once you pull the starter down, you should be able to get to the wires. The main wire, IIRC, is either a 15mm or a 13mm. The small wire should be an 8mm. Installation is pretty much just the reverse. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: '90 Trooper V6 starter swap q? [Re: Richard Saylor] #777951 01/07/07 12:29 PM
ISueYou Offline
Pretty much what Richard said, but there is sometimes a shim between the top of the starter and the mounting surface. Don't lose that shim. I don't think a hillbilly hole would help you too much as far as clearance in getting it out, but I'd like to see it if you do it.
Jay <img src="/forums/images/graemlins/mrt.gif" alt="" />
1989 Trooper 2.8 V6 5-Speed(the daily driver)- Superwinch Hubs, otherwise Stock - $350
1990 Trooper LS 2.8 V6 Auto - Superwinch Hubs, otherwise stock....for now - $182.50
1983 Chevy Blazer - Stock - $150
No Car Payments - PRICELESS
Re: '90 Trooper V6 starter swap q? [Re: Hooplehead] #777952 01/07/07 06:26 PM
*Thanks I'll give it a shot..
Can I leave the skid plate on?
It's dark up there<G> <img src="/forums/images/graemlins/evil.gif" alt="" />
H~
Re: '90 Trooper V6 starter swap q? [Re: Hooplehead] #777953 01/07/07 08:36 PM
The very most forward one, you can, but the one that actually crosses the oil pan, I'd pull it. You might be able to get away with leaving it there, but I'd take it off to make sure it's not in the way. It's only 4 bolts after all.
84 Honda XL185S
Re: '90 Trooper V6 starter swap q? [Re: Hooplehead] #777954 01/08/07 03:04 AM
MISSION ACCOMPLISHED!
Thanks.. starts up great!
H~ <img src="/forums/images/graemlins/patriot.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6122 MB (Peak: 0.6824 MB) Data Comp: Off Server Time: 2026-06-21 12:13:06 UTC
