axle swap #778009 01/07/07 07:29 AM
Do the Rodeo's and Troopers use the same rear axles? I am looking at an 1991 Trooper and a wrecked 1995 Rodeo... I want to swap the drivetrain from the Rodeo into the Trooper.
Re: axle swap #778010 01/07/07 07:40 AM
strawmyers Offline
Isuzu Moderator
Nope, the Trooper has an Isuzu 12-bolt and the Rodeo has an D44.
Sean Strawmyer
Re: axle swap #778011 01/07/07 08:12 AM
9
94redrodeo Offline
They use the same driveshaft flanges so you can use the rodeo driveshaft on the 12 bolt, assuming its the same length which It should be
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: axle swap [Re: 94redrodeo] #778012 01/08/07 05:44 AM
F
Fujisawa_Rob Offline
Be aware of brake differences, the Rodeos were rear drums, no? Just something to think about, not sure if the e-brake cable will be a bolt on, etc.
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: axle swap [Re: Fujisawa_Rob] #778013 01/08/07 06:06 AM
Rodeo Guy Offline
I think 91-92s, and possibly 2wds have drum brakes. The rest got discs.
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
Re: axle swap [Re: Rodeo Guy] #778014 01/08/07 06:19 AM
F
Ah...and the 91-92's were the GM 10-bolt IIRC? Good info.
Re: axle swap [Re: Fujisawa_Rob] #778015 01/08/07 02:54 PM
Bigpoppax2 Offline
That is correct. The only Rodeos to come with drum brakes are the GM 10 bolts and the 98 and up 2wd's had drums.
The 1st gen Rodeo in 2wd may have drums but I've not messed with any 1st gen 2wd's to know.
Joe
Re: axle swap [Re: Bigpoppax2] #778016 01/08/07 08:02 PM
JLEMOND Offline
90-92 rodeos with 4 whl drv had drums
all 4 cyl rodeos have rear drums no matter the year
all rodeos 92 >>>>>>>> 2 wd drum brakes thru 2003
all 4wd rodeos 93 >>>>>> 2004 have rear discs
JERRY
Re: axle swap #778017 01/23/07 01:09 AM
90amigo Offline
I installed a 94 Passport rear in my 90 amigo.Bolted right up,used cable clamps for the e-brake.
90 Amigo,Front 10 bolt with powertrax locker,Rear Dana 44 with Detroit Locker at 5:38.1 R&Ps,Pro Comp MT's 33x12.5 on 15x8 black Rockcrawlers,with a 3" suspension lift.Pro Comp steering Stabilizer.Warn M8000 winch in a ARB bullbar.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6258 MB (Peak: 0.7119 MB) Data Comp: Off Server Time: 2026-06-07 10:31:54 UTC
