"VSC Off" , "VSC Trac", and "Check Engine" lights are on #778178 01/08/07 03:09 AM
lynchknot Offline OP
Is this something that turns on at 80,000 miles or could it be that I may have pulled the exhaust system apart a little due to high centering off road. I think I hear a small exhaust leak when decelerating.
Re: "VSC Off" , "VSC Trac", and "Check Engine" lights are on [Re: lynchknot] #778179 01/08/07 11:04 AM
Adam F Offline
All those lights come on when the check engine light comes on. You need to have your codes read and diagnosed. YOu can get codes read for free at autozone, but no diagnosis. Dealer will have to do that.
Maybe you ripped out an O2 sensor?
97 4R, stock, daily driver
Re: "VSC Off" , "VSC Trac", and "Check Engine" lights are on [Re: Adam F] #778180 01/12/07 01:53 AM
Thanks adam.
Re: "VSC Off" , "VSC Trac", and "Check Engine" lights are on [Re: lynchknot] #778181 02/16/07 11:59 PM
I still haven't fixed it but I have a question. When I stop/park my car, there is a vibration emanating from my gas cap. I assume it's "passing gas". Is this normal or could this be the source of the check engine light? I made sure the cap was tight and it still "farts"
Re: "VSC Off" , "VSC Trac", and "Check Engine" lights are on [Re: lynchknot] #778182 02/17/07 07:54 PM
Dandeman Offline
Toyota Moderator
No it is not normal.. Your gas cap is leaking.. It's actually pulling air in, not leaking out as engine manifold vacuum is used to pull a partial vacuum on the gas tank for emissions reasons.. You probably have error code PO440 set which is defined as follows:
Per the Factory Service Manual...
PO440 will be set when the fuel tank pressure is atmospheric pressure after the vehicle has been driven for 20 minutes.. (meaning air is leaking in and the system can't pull a vacuum on the tank..
Possible Trouble Areas:
Hose or tube cracked, holed, damaged or loose seal.
Fuel tank cap incorrectly installed
Fuel tank cap cracked or damaged.
Fuel tank cracked, holed or damaged.
Charcoal canister cracked, holed or damaged
Vapor pressure sensor
ECM
Re: "VSC Off" , "VSC Trac", and "Check Engine" lights are on [Re: Dandeman] #778183 03/11/07 05:58 AM
Thanks Dandeman
Re: "VSC Off" , "VSC Trac", and "Check Engine" lights are on [Re: lynchknot] #778184 04/30/07 02:12 AM
mtnyoat Offline
Mine just did the same thing at 85k. What did yours end up being? Just curious. I'm taking mine to Autozone tomorrow.
'90 PU 22re, Downey Header, Magnaflow, K&N intake, 31" BFG's, Torsion bars, add a leaf and stuff...
'01 4Runner 3.4, 33" MTR's, OME Lift, ARB'd
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6186 MB (Peak: 0.7090 MB) Data Comp: Off Server Time: 2026-07-09 17:10:06 UTC
