94 yj front locking hubs
#778387
01/08/07 11:25 PM
I want to do a front axle swap with an axle that has locking hubs is there one that will match my dana 30 rear width <img src="/forums/images/graemlins/patriot.gif" alt="" />. I also intend to run 35"-37" tires with 4.88 gears.
broken again
Re: 94 yj front locking hubs
[Re: rockcrusher94]
#778388
01/09/07 10:28 PM
Check that, you said rear d30? what rear axle are you running? It is not a d30.
Why lock outs? reason?
Look at all the new TJs and xjs they run full time front axles with no problem. But they have a front CV driveshaft.
SD
[Re: superdawg]
#778389
01/10/07 03:09 AM
Im looking for a cheap way to lock by welding up my spider gears. I want to put a junk yard axle that has locking hubs and beter brakes for 37" tires, so my front axle wont spin along with my transfercase chain. this will alow no chirping around turns beter handling on the street.Has this been done before the vacum lockind axle is is a poor design on the d30.
broken again
[Re: rockcrusher94]
#778390
01/10/07 03:21 AM
I thought that a 94 yj comes with a dana 30 in the rear. I have a 2.5l
broken again
[Re: rockcrusher94]
#778391
01/12/07 03:59 AM
03 TJ 5 Speed I-6 30X9.50 BFG KO's
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6032 MB (Peak: 0.6670 MB) Data Comp: Off Server Time: 2026-10-24 07:31:50 UTCValid HTML 5 and Valid CSS
