Re: Pilot bearing
[Re: Bigpoppax2]
#778578
01/15/07 10:10 PM
Well I ended up getting out with a slide hammer I rented from Autozone. Flywheel was iffy, wasn't to sure about the condition. I used some liquid blue stuff to make cracks more apparent, I wasn't to sure about the cracks I found, I wasn't sure if they were just on the surface, so I took and had it machined anyway. The machinist stated the flywheel was in really good condition after he finished with it.
On, another note, would anybody happen to have a shop manual (not the typcial Chilton or Haynes manual) that would list the sizes of each bolt and their location on the bellhousing. The guy (next door neighbor) who took the bolts out just ended up setting them on the ground rather than putting them in the bellhousing template that I made.
2000 Chevy Tahoe nothing special. 1990 Isuzu Amigo, 3" lift, 31x10.5x15 BFG All Terrain (Street), 33x12.5x15 (offroad), Pacesetter header, some ATM rash. More mods to come......
Re: Pilot bearing
[Re: Billdo]
#778579
01/19/07 05:53 PM
So, no shop manual is around, that lists which bolt goes where?
Re: Pilot bearing
[Re: Billdo]
#778580
01/19/07 06:36 PM
STARTING AT THE TOP STARTER STUD GOING IN A CLOCKWISE DIRECTION, THE STUD IS A 10MM BY 1.25 THREAD , FIRST THREE BOLT S SHOULD BE 10MM X 40MM X 1.25 THREAD THEN A SHORT THRU BOLT AND NUT, MAYBE TWO PLACES IF SO THEY WILL BE SIDE BY SIDE , AND THEN A LONG ABOUT 45 MM THAT GOES THRU THE BELLHOUSING AND INTO THE ENG BLOCK EAR. WATCH FOR THE BOTTOM STARTER BOLT , IT IS A 10MM ABOUT 35 MM IN LENGTH BUT IT IS A 1.50 MM THREAD AND IT IS EASY TO GET MIXED UP. IF YOU ARE STILL HAVING TROUBLE USE THIS METHOD AS YOUR BOLTS MAY HAVE BEEN SUBSTITUTED SOME WHERE ALONG THE WAY, STICK THE BOLT THRU THE BOLT HOLE FROM THE BOTTOM OF THE BOLT HEAD TO THE SURFACE OF THE TRANS CASE THERE SHOULD BE ABOUT 3/8TO 1/2 INCH MAX CLEARANCE THIS WILL GIVE YOU THE RIGHT LENGTH ALLSO.. THERE IS ALLSO A THRU BOLT AND A NUT ON THE PASS SIDE RIGHT ABOUT THE STARTER MOUNT JERRY
