Jarring in the rear axle?? #778644 01/09/07 11:54 PM
lucasgreff Offline OP
In my 86 trooper. Every time I let off the gas and press down again I get a jarring like the joints are loose and it is taking up the slack in them. I checked them all and they all seem to be tight and greased. Is this a common problem with 86 troopers or something I shoudl worry about possibly in the diff case itself??
thanks
86 Trooper II
Stock except for the Rust and dents that came with it. Restoration while being a daily Driver is in progress. Completed so Far-Front Brakes, Rear Brakes, Frame restoration, 1 1/2" lift shackles, custom front and rear bumpers
Re: Jarring in the rear axle?? [Re: lucasgreff] #778645 01/10/07 01:58 AM
Jim_Paget Offline
I once got similar symptoms from loose u-bolts on the spring packs.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Jarring in the rear axle?? [Re: Jim_Paget] #778646 01/10/07 11:06 PM
thanks, I will see if they tighten up anymore.
Lucas
86 Trooper II
Re: Jarring in the rear axle?? [Re: lucasgreff] #778647 01/11/07 12:05 AM
mrjohnson Offline
You might take a look at the hangers for the muffler/tailpipe assy.
1990 TROOPER XS
Re: Jarring in the rear axle?? [Re: mrjohnson] #778648 01/12/07 11:37 PM
what would the exhaust have to do with a jarring when I press the accelerator?
please explain
thanks
Lucas
86 Trooper II
Re: Jarring in the rear axle?? [Re: lucasgreff] #778649 01/13/07 12:30 AM
mrjohnson Offline
It may have some slack in the bushings attached to the hangers and when the throttle is applied,
(or released) torque is multiplied along the length of the exhaust system.
And (it may) resonate as jarring like feel.
Or not.
YMMV
1990 TROOPER XS
Re: Jarring in the rear axle?? [Re: mrjohnson] #778650 01/13/07 01:59 AM
mlclark Offline
Isuzu Moderator
They guys have given you several things to look at. Now it is time for you to crawl under there and take a good look. Recheck those u-joints. Pull off the drive shaft and check for play (radial and in/out) in the pinion. It may be time to drain the tranny or rear end to see if there are chunks.
Remember, you are working with a 20-some year old truck. Things loosen up over time and while nothing maybe "loose" the additive effect of all the wiggles will make for some strange behavior.
Just to check, this is something under normal driving conditions, right? You aren't accelerating, letting off and then stabbing the gas, right? I can get any vehicle to lurch or jar by building up slack in the cost side of the entire drive train and then flooring it.
Good Luck,
Michael
Re: Jarring in the rear axle?? [Re: mlclark] #778651 01/15/07 04:43 PM
Alright. This weekend I crawled under there. Tightened all the axle bolts(none were loose) Changed the rear diff fluid and tranny fluid.(dirty but full) greased all the places I could grease underneath. And checked for play in the shafts (very little)
THen I took it off the blocks and sure enough the majority of the jarring went away. Now it only does it if I lay off and then jam the accelerator which happens on any vehicle.
thanks
Lucas
86 Trooper II
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6238 MB (Peak: 0.7016 MB) Data Comp: Off Server Time: 2026-06-18 13:14:04 UTC
