problems removing o2 sensor #778712 01/10/07 04:02 AM
SilverWilly Offline OP
OK, so how do you guys remove the bank 2 sensor 1 o2 sensor? There is this large brace in the way, not to mention the exhaust. I have an o2 socket but there's too much play in my socket driver to get any good force, I keep running into the transmission pan. Do I have to remove this frame brace?
BTW, I have searched this site up and down and there seems to be some conflicts regarding which side is bank 1 / bank 2. I have seem it claimed and/or corrected both ways, LOL. Is this because some troopers/rodeos are right hand drive? I think that if you were looking at the engine from the front of the truck, bank 1 is on the left, and bank 2 is on the right. Is this correct?
1996 Honda Passport 4X4
1992 Twin Turbo Z
Re: problems removing o2 sensor [Re: SilverWilly] #778713 01/13/07 05:54 AM
Canucklehead Offline
Bank 1 is the passenger's side... it corresponds to the odd numbered cylinders. Bank 2 is the driver's side.
Steve
'97 Rodeo 5spd. 3.2L SOHC V6 4WD
Re: problems removing o2 sensor [Re: SilverWilly] #778714 01/15/07 04:51 PM
Smiley Offline
All I can tell you about removing and installing O2 sensors on a 1996-97 Rodeo is this:
Without a Body Lift, I have *no idea* how I would have done mine -- it was pretty tight work, even then.
Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: problems removing o2 sensor [Re: Smiley] #778715 01/21/07 02:44 AM
A
anubis Offline
I just replaced my bank 2 sensor. and the check engine light did not go away. Do I need to have it cleared or can I just unhook the battery and get the same result.
BTW the body lift did make this easy with the proper tools.
2002 Honda Passport. 3 inch Indy4x lift with 912 OME's. 265 75 BFG m/t's with a 3 inch body lift, safari rack, tube sliders, tube rear bumper, on-board air
Re: problems removing o2 sensor [Re: anubis] #778716 01/24/07 05:49 PM
tobeornottobe Offline
hi had my o2 sensor changed and the light was still on....someone told me it is i button inside dash ...behind the speedo....took off cover and lo and behold there it was pushed it and light was out... i have an 88 trooper II
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6079 MB (Peak: 0.6726 MB) Data Comp: Off Server Time: 2026-10-24 13:10:47 UTC
