Error Codes Galore!!! How can this be??? #778948 01/10/07 09:33 PM
Tygger Offline OP
The codes are telling me that all my O2 sensors are bad! About 1yr ago, I got an error code for one of my pre-cat O2 sensors (Not sure which one, will need to search the archive) and I replaced it with a Bosch sensor.
Now, about 1yr later, I get all these codes... <img src="/forums/images/graemlins/zombie.gif" alt="" /> Are all of my sensors now bad or could it be some weird electrical problem???
P0134 - 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
P0135 - 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0141 - 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0154 - 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 - 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0161 - 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P1870 - Transmission Component Slipping
1997 Isuzu Rodeo S 4WD
Re: Error Codes Galore!!! How can this be??? [Re: Tygger] #778949 01/10/07 09:39 PM
Richard Saylor Offline
To me, I'd start checking the wiring harness and make sure it hasn't gotten melted/cut/etc. If that all checks out, then I'd start checking the components themselves.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Error Codes Galore!!! How can this be??? [Re: Richard Saylor] #778950 01/11/07 03:01 AM
Tygger Offline OP
Good advice. My front left (driver side) O2 harness is kinda melted.
Why did Isuzu design it like this?? O well...
Would this one melted harness effect all of the other sensors and throw the errors as previously listed?
Thanks again!
Re: Error Codes Galore!!! How can this be??? [Re: Tygger] #778951 01/11/07 03:23 AM
SilverWilly Offline
I agree that these o2 sensors locations are not ideal. What were they thinking? If you were fouling up your o2s after just one year I think you'd notice the truck running really rough. You can test the o2s on a bench if you have a propane torch and a multimeter. Here's a link that shows how
1996 Honda Passport 4X4
1992 Twin Turbo Z
Re: Error Codes Galore!!! How can this be??? [Re: SilverWilly] #778952 01/12/07 05:20 AM
Tygger Offline OP
How can I fix the engine side harness??? On the O2 side, I can just get a new sensor, but what can I do about the other side?
Thanks
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6069 MB (Peak: 0.6719 MB) Data Comp: Off Server Time: 2026-11-16 08:39:45 UTC
