TJ body lift
#779182
01/11/07 11:14 AM
Which should be the external diameter and the hole diameter of the spacers for a TJ body lift?
Re: TJ body lift
[Re: georgek]
#779183
01/12/07 08:37 AM
Hello everybody!
A friend of me has recently buy a TJ Golden Eagle and he wants to set 33' tyres. He has a 1.5' suspension lift but it seems to be necessary a body lift in order to avoid the trimming. Does anybody know thich should be the dimensions of the spacers for a 1.5' body lift? (external diameter and hole diameter).
Re: TJ body lift
[Re: georgek]
#779184
01/12/07 07:25 PM
Are you making your own? I dont know, but I imagine if you put a caliper on one of the body mounts that would tell you the outside, and if you pull a bolt out you could see how big a hole you need.
Josh
80 CJ-7. It runs
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5903 MB (Peak: 0.6440 MB) Data Comp: Off Server Time: 2026-06-23 14:16:22 UTCValid HTML 5 and Valid CSS
