1999 4runner transmission #779221 01/11/07 05:42 PM
I am new to the forum and my 1999 4runner is new to me.
I do not have a owners manual I am looking for general guidelines on use of the transmission. Particularly deployment of 4wd, when to use which range, at what maximum speed, etc.
Any advice appreciated.
Re: 1999 4runner transmission #779222 01/11/07 11:26 PM
boiserunner Offline
Shifting into 4 hi in and out can be done at moderate speed. 4low you need to be stopped and I put mine into park.Is your a limited w/ locking rear dif?
1979 cj-7 350sb t18a
1998 4runner sr5 4wd auto
1991 dodge clubcab 4wd manual
1931 ford model A coupe(got decklid lookin for
rumble seat)
Re: 1999 4runner transmission [Re: boiserunner] #779223 01/12/07 12:24 AM
Thanks,
It is a limited w/the locking rear diff.
The card in the visor indicates you can drive in 4WD hi up to 60, I have friends who say they would never go over 40 in 4WD.
What I am wondering is at moderately high speed on mixed surface (40 - 50 mph), should I just use the 4WD button on the side of the transfer case shifter as needed (sometimes it takes a minute or 2 to engage), or just stop and shift the transmission to 4hi until I am in the clear.
Thanks for your input.
Re: 1999 4runner transmission #779224 01/12/07 02:33 AM
boiserunner Offline
They must have changed some stuff from 98 to 99 I dont have a "4wd button on the side of the transfer case shifter".The only time I have to stop is to engage 4low. I also stop to lock the rear diff. You should only use 4low or diff lock in off road situations.The rear diff lock is a button on the left of the wheel on the dash. Do you have a center diff lock?? I thought that was only on gen 4 4runners. Then you get into hill decent and all kinds of stuff I dont have.
rumble seat)
Re: 1999 4runner transmission #779225 01/12/07 02:34 AM
willzrunna96 Offline
therese no reason to be doing 50 mph in 4wd....do it slower.
Re: 1999 4runner transmission #779226 01/12/07 02:52 AM
kewlynx Offline
I've tried this a couple of times while in motion; just plain ol' ADD front, no elocker.
Don't. Once that front end engages, you could break traction, ironically enough. ESP if on ice.
I usually wind up engaging mine once I get to town to have better control with the intersections, but I'm under 30 mph when I do this, OR, I simply pull over, put 'er in, and get back out there.
Follow your owner's manual.
**ubi apis- ibi salus**
Re: 1999 4runner transmission [Re: kewlynx] #779227 01/13/07 04:26 AM
Thanks for all of your responses.
I am ordering an owners manual.
re: the 4wd shift button, it is on the shifter of the transfer case. I plan on using the locking diff in case of emergency only. In the meantime, sub-50mph 4wd sounds reasonable.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6121 MB (Peak: 0.6892 MB) Data Comp: Off Server Time: 2026-07-15 00:20:06 UTC
