Re: 1990 Montero ticking [Re: pcc] #779516 01/16/07 06:44 PM
BobShaw Offline
I think that CD2 is an old additive for hydraulic valves. It seemed to work but there may be something better now.
Re: 1990 Montero ticking [Re: sparky101] #779517 01/18/07 06:54 AM
sparky101 Offline OP
If I switch to synthetic motor oil will this cause any problems like seals beginning to leak ect,also would it be a good idea to try a motor flush oil additive.
1990 Monty,LSD,3.0 V6,AT
Re: 1990 Montero ticking [Re: sparky101] #779518 01/18/07 10:49 AM
P
pcc Offline
Synthetics are not a bad idea or a good idea. My understanding is they have better cold flow characteristics and better heat stability but do you need both of those features for the price. I use synthetics in two of my vehicles and dino oil in the other. To offset the price of the synthetics I use longer drains but have relied on oil analysis to make sure the oils are holding up between changes. Synthetics have better cleaning action and will not affect seals unless I guess if dirt is helping to seal any leaks. The 0w-40 synthetic I use in my Montero is not available in a dino oil and I am extremely happy with the way it performs so far. The key to any oil and engine life is keeping it clean. If you have always kept the oil clean then a flush is not necessary. It will also take a couple of oil changes to flush out the dino with the synthetic to see the full affect of the synthetic. You may have to experiment a bit to get an oil you are happy with. I am still analysing the two different brands of synthetics I use and am not committed to either yet. Life is a journey. <img src="/forums/images/graemlins/confused.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.5998 MB (Peak: 0.6696 MB) Data Comp: Off Server Time: 2026-06-07 03:52:07 UTC
