squeaky steering wheel/colmun #779523 01/12/07 05:18 PM
bhartwell59 Offline OP
hi all,
i recently noticed a squeaking or creaking noise coming from my '87 yj steering wheel or the top of the colmun whenever i make a turn. it doesn't sound major just annoying.
is there something that needs replacing or a shot of wd40?
-b
4.2 '87 yj, 263,000 miles, mopar mpi, 33" mud bfg, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 shaft conversion, tom wood's hd driveshaft, magnaflow/custom exhaust, 4wd bumper/swing-out tire carrier
Re: squeaky steering wheel/colmun [Re: bhartwell59] #779524 01/12/07 07:22 PM
BobRowe Offline
There is a bearing between the steering shaft and the steering column under the upper part of the steering column cover. That bearing is normally greased, and the grease usually lasts a lifetime. Sometimes a bushing is used instead of a bearing.
Getting to the bearing is a real PITA. Y0u must first remove the horn button, steering wheel and shaft nut with a puller, then remove the turn signal switch, etc. That's just to get to the bearing.
I'd make sure that the problem was with a dried out bearing, and not something else rubbing. If it is the bearing, I'd just try shooting it with WD-40, or one of those semi-liquid greases that come in an aerosol can and a tube you can put on the can. Don't overdue it.
Actually, if it's the bearing and there is no excess play in the steering shaft, and unless you're a perfectionist, I'd just let it go. Turn the radio up louder! <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: squeaky steering wheel/colmun [Re: BobRowe] #779525 01/12/07 07:30 PM
BigJim Offline
ANYTHING but wd-40! There are a hundred pressurized lubericants out there that WILL lubricate.. wd-40 is a protecterant and not much of a lubricant at all. It dries and leaves varnish where you do NOT want more varnish.
Re: squeaky steering wheel/colmun [Re: BigJim] #779526 01/12/07 08:53 PM
thanks guys... i'll go rent a steering wheel puller and see what i find.
-b
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6027 MB (Peak: 0.6587 MB) Data Comp: Off Server Time: 2026-11-02 19:38:25 UTC
