Have 2 Trackers And No 4WD In Either Of Them #779658 01/13/07 10:26 AM
I have two Trackers and the 4wd is out on both of them. I remember years past hearing that these things had a weak spot in the transfer system, but I can't remember the details. Can anybody out there that can catch me up on this.
Re: Have 2 Trackers And No 4WD In Either Of Them #779659 01/17/07 07:34 AM
Davepet Offline
Let's start with what you've done so far so we don't waste time telling you to do that.
Is it safe to assume that you've checked your hubs already & they check out OK?
I haven't heard of a weak spot in the transfer, but my knowledge is mostly from my wife's 98 tracker.
Dave
Re: Have 2 Trackers And No 4WD In Either Of Them #779660 01/20/07 08:57 PM
DesertTracker Offline
I've had a few Trackers (one I sold with over 200,000 miles) and never found a weak spot in the 4WD system.
Davepet has a good plan. Start with telling us why you believe there is no 4WD operation and we'll try to suggest things not already tried.
I'll suggest a couple of preliminary checks. The first step is to confirm that no 4WD exists. I would lift all four corners, engage the transfer case and hubs and spin a tire and see what turns (engine off!!). If everything turns, you have 4WD. If the front shaft turns, but not the front wheels, its hubs or even the front axle; it could even be that the shifter is not egaging the transfer case, but I would suspect that the shifter would feel loose if thats the case.
Another simple first step would be to pop a hub of and look inside; lots of gunk could prevent proper operation. I'm not sure if your model has auto or manual hubs, but if manual, engage and disengage while looking inside and see what happens...
Good Luck.
Ridgecrest, CA
2000 Tracker 2-dr
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.005s) Memory: 0.5877 MB (Peak: 0.6400 MB) Data Comp: Off Server Time: 2026-10-26 22:33:05 UTC
