Please help with clutch problems! #779859 01/13/07 08:51 PM
rustygirl Offline OP
My '95 with now 150,000 miles is having clutch problems. We recently replaced the slave cylinder, because it had sprung a small leak, and after that it's started to act up.
When the clutch is pushed to the floor the pressure seems to leave and the clutch slowly engages while the petal is still being held to the floor.
When I release the clutch petal, the next time I push the clutch in, it works fine again for the first time, then looses pressure like before and starts engaging the clutch, assuming you hold the clutch in.
also, sometimes the clutch will engage REALLY prematurely when I'm engaging the clutch with the truck in gear.
We've bled the clutch just like is says so in the haynes...
Any suggestions?
1995 Toyota Tacoma: 4X4, Extended Cab, 5sp, 2.7L 4 cylinder (3RZ), 31 X 10.5 BF Goodrich All Terrains.
Re: Please help with clutch problems! [Re: rustygirl] #779860 01/13/07 10:10 PM
Denvertaco Offline
If you have bled the system and replaced the slave cyl then the only thing left is the clutch cyl. You should get the same action each time you push in the clutch. If not, the one cyl or the other is failing. Give that a shot.. <img src="/forums/images/graemlins/kewl.gif" alt="" />
03 Double Cab TRD.. ARB, warn winch, OME coilovers, Alcan leafs, Bilstiens, Sky E-locker guard, etc, bla bla bla
Re: Please help with clutch problems! [Re: rustygirl] #779861 01/13/07 10:16 PM
john_luttrell Offline
If it's been bled properly and still has the problem; it's the clutch cylinder up top that's bad.
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5925 MB (Peak: 0.6461 MB) Data Comp: Off Server Time: 2026-06-17 11:57:20 UTC
