93 3.2 sohc trooper crank sensor #779893 01/13/07 11:18 PM
L
lowflying90 Offline OP
i recently picked up a 1993 isuzu trooper. it has the 3.2 sohc engine. the front of the engine is tore off exposing the timing beltsright now. the previous owner said it ran fine one day, the next day it wouldn't start so he thought it had a broken timing chain. he siad it would crank over just fine. he was trying to change the crank sensor however it snapped off with part still in the block. any ideas how to get this out?
also, does this symptom sound like a crank sensor was the problem or do you think something else is the problem.
thanks,
jeff
Re: 93 3.2 sohc trooper crank sensor [Re: lowflying90] #779894 01/18/07 08:46 PM
L
anyone?
Re: 93 3.2 sohc trooper crank sensor *DELETED* [Re: lowflying90] #779895 01/26/07 11:18 PM
A
all we'll drive Offline
Post deleted by all we'll drive
1995 Trooper 3.2 single, 5 speed, OME 912's, T-bar crank, G80, 285 M/T's, custom dents, random rust
1999 Trooper 3.5, auto, TOD, K&N, tint (wife's car can't improve it)
1988 Trooper LS 5 speed SOLD
Re: 93 3.2 sohc trooper crank sensor [Re: all we'll drive] #779896 01/26/07 11:25 PM
Richard Saylor Offline
Uh, ya, if the crank sensor is broken, it more than likely won't be able to start. The crank sensor tells the computer where the crank is in its revolution so that it knows when to inject fuel and when to set off the spark plug. So, if it doesn't know where it's at, it doesn't know when to do the other stuff, thus the no start.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: 93 3.2 sohc trooper crank sensor [Re: Richard Saylor] #779897 01/29/07 12:20 AM
L
the crank sensor is broke now. it wasn't broke prior to not starting. the owner decided to change it and snapped it off trying to remove it.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6073 MB (Peak: 0.6713 MB) Data Comp: Off Server Time: 2026-06-21 19:00:28 UTC
