'91 Trooper heater blowing luke warm...
#780381
01/15/07 11:05 PM
K...#1 Yes. looked in "Search" engine.#2. Can I get a lil help?  I am driving a great Trooper (besides the temporarily messed up alignment and really difficult gears that I'm told is a syncronizer problem...yeah. I'm clueless with that one) but my one issue is the lack of heat.It's not too bad. I live in Southern IL and we don't see temps drop too far...exluding this coming week of teens! But when I'm chilled to the bone, I'd like somethin better that 58 degrees!! I used to own an 84 Troop and that thing would swelter you till you had to open windows in the winter! I loved it. But this 91 has never gotten above 60. Unless it's summer...in which case it's Canadian made and has NO A/C (thanks Canada!) <img src="/forums/images/graemlins/lol.gif" alt="" />So. Please send some info. I've heard the relay problems, but that would make it fail completely right? And could it just be a filter issue? If so, what's my cure?Thanks in advance (or whatever part store you use!)Dana
'91 LS Trooper~ 1.5" Susp. & 3" Body Lift, 33"BFG M/Ts, custom double sliders, Indy4x bumper,Herc'd lower body panels, Hella 550 lights, custom rear shelf and speaker box, customized console, blue grill strobe lights and wig-wag headlights
Re: '91 Trooper heater blowing luke warm...
[Re: K9Troopin]
#780382
01/15/07 11:41 PM
I am having the same problem with my 86 trooper. I have replaced all the filters within the last two months and changed all the fluids. I don't know what might be wrong so I am in the same boat as you.
Lucas
86 Trooper II Stock except for the Rust and dents that came with it. Restoration while being a daily Driver is in progress. Completed so Far-Front Brakes, Rear Brakes, Frame restoration, 1 1/2" lift shackles, custom front and rear bumpers
[Re: K9Troopin]
#780383
01/15/07 11:53 PM
Just a thought,
Is there a possibility that the cable is stretched? I had that problem on my '85 Toyota, so I would only get 70% of the heat. New cable, 100% heat kinda like living with the<img src="/forums/images/graemlins/evil.gif" alt="" />
<img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
1995 Trooper 3.2 single, 5 speed, OME 912's, T-bar crank, G80, 285 M/T's, custom dents, random rust
1999 Trooper 3.5, auto, TOD, K&N, tint (wife's car can't improve it)
1988 Trooper LS 5 speed SOLD
[Re: all we'll drive]
#780384
01/16/07 12:11 AM
Broken thermostat is my guess.
2000 XJ Classic - Classically a POS 1994 Isuzu Amigo XS -Sold 1972/3 CJ5 Glass body, 5" lift 34's. 5 years of work coming to an end.
[Re: K9Troopin]
#780385
01/16/07 02:48 AM
TAKE A LOOK UNDER THE LEFT SIDE OF THE DASH AND FIND THE WATER CONTROL VLV ,IT IS UP ABOVE THE THROTTLE ASSY THERE IS A LITTLE PLASTIC ARM ON THE VLV ITSELF AND A SNAP IN STEEL ROD THAT GOES BACK TOWARD THE DASH BOARD , MOVE THE TEMP LEVER BACK AND FORTH AND MAKE CERTAIN THAT THE VLV IS OPENING ALL THE WAY ,, BEST PLACE TO START IS ON THE PASS SIDE OF THE HEATER BOX, BUT FIRST POP THE STEEL ROD OUT OF THE SMALL ARM AND JUST LET IT HANG LOOSE ,NOW GO TO THE OTHER SIDE OF THE HEATE BOX AND MOVE THE HTR LEVER BACK AND FORTH AND YOU WILL SEE IT MOVING A ANOTHER LEVER ON THE PASS SIDE TO THE RIHT AND DOWN BY THE SIDE OF THE RADIO AS YOU MOVE THE LEVER BACK AND FORTH WATCH AND MAKE CERTAIN THAT THE LEVER IS MOVING ALL THE WAY FORM ONE OF IT,S TRAVEL TO THE OTHER ,IF NOT REMOVE THE SMALL SNAP CLIP AND ADJUST THE CABLE UNTILL IT DOE,S , NOW WITH THAT ADJUSTED GO BACK TO THE OTHER SIDE AND MOVE THE LEVER ALL THE WAY TO THE HOT POSITION AND THEN PUSH THE LITTLE PLASTIC ARM ALL THE WAY FORWARD AND SNAP THE STEEL ROD BACK IN PLACE ,, OK NOW YOU WATER VLV IS ADJUSTED, NOW DO THE SAME ADJUSTMENT WITH THE BLEND DOOR LEVER BY MOVING IT BACK A ND FORTH UNTILL WHEN YOU HEAR THE DOOR SNAP SHUT IN THE HTR BOX AS , EASY WAY TO ADJUST THIS ONE IS TOO MOVE THE LEVER ALL THE WAY TO THE LEFT AND LOOK AT THE CABLE AND LEVER ON THE DRV SIDE THE LITTLE TANG THAT THE CABLE GOES IN SHOULD BE POINTING AT ABOUT 7 OCLOCK TO HAVE IT ADJUSTED CORRECTLY, IF NOT REMOVE THE SNAP CLIP AROUND THE CABLE , MOVE THE LEVER ALL THE WAY TO THE LEFT AND THE LEVER ALL THE WAY DOWN TO SEVEN OCLOCK AND THEN REPLACE THE CABLE SNAP AND SEE IF YOU HTR WORK ANY BETTER NOW , IF NOT YOU MAY AHVE A WATER BLOCKAGE IN ONE OF THE LINES .. JERRY ALLSO AMKE CERTAIN YOU HAVE A GOOD THERMOSTAT IN THE ENG
[Re: K9Troopin]
#780386
01/16/07 06:01 PM
I agree with the others: once you've established that the heater circuit is opened fully, check that thermostat! If it is missing or stuck open, the engine may not completely warm up. This effect is amplified in Winter, and if your driving is on the freeway. Is the heat guage working? Does it show that the engine is fully hot?
A thermostat / gasket will run you less than $10. A heater core replacement will drive a sane person crazy.
Good luck!
1993 Trooper "Purple People Eater"
UPDATE! Re: '91 Trooper heater blowing luke warm...
[Re: K9Troopin]
#780387
01/23/07 07:53 PM
Took it to a local shop for alignment too and they checked and replaced the thermostat.  It's back to blowing air hot enuff to run me out into the snow....if we had any this year... Thanks to you all. Dana <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: UPDATE! Re: '91 Trooper heater blowing luke warm...
[Re: K9Troopin]
#780388
02/02/07 04:36 PM
I just replaced my therostat and mine is now blowing hot air as well. Good thing to it just reached -25 with windshield.
[Re: lucasgreff]
#780389
02/02/07 04:43 PM
it just reached -25 with windshield. It would be even colder without the windshield! <img src="/forums/images/graemlins/lol.gif" alt="" />
Steve Carlson - 95 Trooper LS expo rig Serenity now!
