Page 2 of 3 1 2 3
Re: Quick Question? [Re: litnin] #780545 01/17/07 01:13 AM
Richard Saylor Offline
I guess I should have made myself more clear ... what year trooper does HE have. <img src="/forums/images/graemlins/wink.gif" alt="" />
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Quick Question? [Re: Richard Saylor] #780546 01/17/07 01:20 AM
litnin Offline
Ahhh... Gotcha! <img src="/forums/images/graemlins/kewl.gif" alt="" />
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Quick Question? [Re: Richard Saylor] #780547 01/17/07 06:18 AM
E
EricW Offline
Mid(?) to late 2nd Gens had the modified 12 bolt, bigger ring/pinion, axle shafts.
I've been keeping my eye out for 4.77 thirds. I own a 96 Trooper, would the third members be "plug and play" or will anything else have to be changed out?
1996 Trooper S 3.2 5sp OME919/ProComp ES9000
BFG Dueler A/T REVO 265/75R16 w/Snowflakes
1991 Trooper 2.6 5sp 33x12.5 BFG T/A
Re: Quick Question? [Re: EricW] #780548 01/17/07 10:26 AM
As long as you don't have the modified 12 bolt, then it'd be essentially just swapping out the 3rds. I think you've got the standard 12 bolt still. I *think* the switch was in 98? Hopefully someone that knows for sure will chime in and confirm the year that they started the modified 12 bolt. <img src="/forums/images/graemlins/kewl.gif" alt="" />
84 Honda XL185S
Re: Quick Question? [Re: Richard Saylor] #780549 01/17/07 02:41 PM
RobG Offline
98, thats correct. with 96, you'll have the std D44 like 12-bolt.
Eric, keep my name handy... I might be looking to sell our 4.77 thirds out of our '89 RS here in the next couple of months.
-Rob
Re: Quick Question? [Re: RobG] #780550 01/17/07 03:26 PM
BigSwede Offline
Might be a minor issue with the ABS, but I don't know the details.
Serenity now!
Re: Quick Question? [Re: BigSwede] #780551 01/17/07 03:50 PM
strawmyers Offline
Isuzu Moderator
I think you're right, Steve. The earlier 12-bolt used one sensor mounted in the 3rd member for ABS. Later versions had a sensor mounted at each wheel. Not sure when the transition was, though. <img src="/forums/images/graemlins/confused.gif" alt="" />
Sean Strawmyer
Re: Quick Question? [Re: RobG] #780552 01/18/07 01:11 AM
Thanks for confirming that Rob. <img src="/forums/images/graemlins/cheers.gif" alt="" />
84 Honda XL185S
Re: Quick Question? [Re: BigSwede] #780553 01/18/07 01:56 AM
E
EricW Offline
I honestly have not done alot of reserch on the 4.77 thirds, I just pay attention to what gets posted (and by whom). Most say it's a direct swap, but I know mine has an ABS sensor on top of the rear third that would have to be addressed. I'm guessing that I would just have to disable the ABS and tie the harness up out of the way.
Re: Quick Question? [Re: RobG] #780554 01/18/07 02:04 AM
E
EricW Offline
Let me know when the time comes. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6466 MB (Peak: 0.7686 MB) Data Comp: Off Server Time: 2026-07-15 18:37:10 UTC
