Oil coming out of PCV valve? #780597 01/16/07 08:44 PM
Nix_Toy Offline OP
Hey everyone, I just opened my hood on the \'85 to check my oil, and I noticed that the hose that connects to the PCV Valve is wet with oil, and there is some dripping of oil underneath the hose clamp on the valve. Is this normal, or a sign of something bad? Also, my oil was like a quart low.. Ive found that the bottom of my truck is coated with a light film of oil (the block, tranny, and some of the front frame rail), but I\'ve never noticed a leak anywhere.. where would be a good place to start looking for a leak? Thanks for any input guys!
-Nick<img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Oil coming out of PCV valve? [Re: Nix_Toy] #780598 01/16/07 11:28 PM
Adam F Offline
Could be a clogged PCV valve (jiggle it, can you hear something rattling?) or could be bad piston rings causing blow by.
Here's another post just the other day with similar problems
http://www.4x4wire.com/forums/showf...mp;amp;sb=5&o=14&fpart=1
97 4R, stock, daily driver
Re: Oil coming out of PCV valve? [Re: Nix_Toy] #780599 01/17/07 01:47 AM
E
ephwang Offline
Front oil seal or oil pump seal are common places to look for leaks.
85 XtraCab SR5 4x4
85 XtraCab Deluxe 4x4
Re: Oil coming out of PCV valve? [Re: ephwang] #780600 01/17/07 05:16 AM
4Crawler Offline
If that hose is old and cracked, oil can leak out. Try a new hose and see if that fixes that leak. It worked for my '85.
Re: Oil coming out of PCV valve? [Re: ephwang] #780601 01/22/07 09:34 PM
A
allochris Offline
If it does leak at those places, what does that imply?
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: Oil coming out of PCV valve? [Re: allochris] #780602 01/22/07 09:52 PM
4Crawler Offline
That the front oil seal is leaking I suppose. Often associated with a groove in the crankshaft pulley that may require a speedi-sleeve to correct (along with a new seal).
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6122 MB (Peak: 0.6981 MB) Data Comp: Off Server Time: 2026-06-17 10:40:35 UTC
