windshield washer nozzle
#781279
01/18/07 05:45 PM
One of the windshield washer nozzles doesn't spray at all. Washer pump works fine, fluid through the line to the nozzle assembly. I tried working a small piece of wire through the top side of the nozzle but couldn't get it to go all the way through. I assume the nozzle is clogged by something (maybe lime/calcium deposits after all these years?). I would rather not remove the nozzle assembly if possible since other wiring/tubing is connected to it. Any other ideas on how or what to use to clear it? Thanks, Jim Tulsa '89 two door v6 auto
Re: windshield washer nozzle
[Re: 'ol trigger]
#781280
01/18/07 05:53 PM
Removing the nozzle is actually pretty easy. I'd do that and throw it in some lime-away or some other calcium deposit disolving fluid for a day or two then check it again. It could also be a tiny rock or something blocking it as well.
[Re: off-roader]
#781281
01/18/07 06:55 PM
how do you remove the lines?
[Re: off-roader]
#781282
01/18/07 06:55 PM
Put some compressed air to it. That's happened before on my pickup and compressed air cleared it right out.
?_________ |_|_|\____\___ l-----[O]≡≡≡≡[O] ()_)()_)-----)_) Stay the Trail!
[Re: CapnCrunch]
#781283
01/19/07 01:33 AM
my 89 lwb did the same thing and I couldn't get it to work right so I just bought some nozzle jets and put those one, they each have three little jets so there's 6 streams of fluid being sprayed, works great. http://rides.webshots.com/photo/2271842990049304464tNBTwethat's the only pic I have that shows them, you can see the two black things on the hood.
1989 Montero 4dr V6 3.0l
[Re: 89montero]
#781284
01/19/07 03:34 PM
If lime-away is nt available you can also use some white vinegar.
Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6103 MB (Peak: 0.6807 MB) Data Comp: Off Server Time: 2026-06-20 20:25:11 UTCValid HTML 5 and Valid CSS
