YJ trans id needed (pic inside) #781490 01/19/07 02:50 AM
A
ADY Offline OP
serial #903047002 five speed 16.5'long in 88 wrangler.I want to service the fluids and have no idea as to what this tranny is.THANKS IN ADVANCE.one thing it's not a BA10
Re: YJ trans id needed (pic inside) [Re: ADY] #781491 01/19/07 04:14 AM
JeePete Offline
What Engine do you have? AX-5 if it's a 4 cyl, AX-15 if it's a six, they didn't put AX-15's on sixes in wranglers 'till mid 89 but lots of people replaced ba-10s with them it looks like an AX-15.
Re: YJ trans id needed (pic inside) [Re: JeePete] #781492 01/19/07 05:29 AM
A
ADY Offline OP
4.2 I6 .I too think it is the ax15,however it has ATF for fluid in it now, haynes manuel says to use gl5 is this correct?.The tranny has been swapped out with a rebuilt unit but this was done before i purchased it.
Re: YJ trans id needed (pic inside) [Re: ADY] #781493 01/19/07 06:00 AM
JeePete Offline
The Factory Service Manual says use 6.75 pints of API GL5/SAE75W-90 oil in a 4wd version AX-15. I'd get that ATF out of there pronto! The T-case uses ATF. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: YJ trans id needed (pic inside) [Re: JeePete] #781494 01/20/07 05:19 PM
superdawg Offline
Arctic circle?, ATF. otherwise I use 80-90 durablend 1/2 synth. The trans will be 100% destroyed w/atf in a normal climate.
SD
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6042 MB (Peak: 0.6685 MB) Data Comp: Off Server Time: 2026-06-20 15:28:36 UTC
