YJ trans id needed (pic inside)
#781490
01/19/07 02:50 AM
serial #903047002 five speed 16.5'long in 88 wrangler.I want to service the fluids and have no idea as to what this tranny is.THANKS IN ADVANCE.one thing it's not a BA10 ![[Linked Image]](http://img.photobucket.com/albums/1003/m35m35/trans2.jpg) ![[Linked Image]](http://img.photobucket.com/albums/1003/m35m35/trans1.jpg)
Re: YJ trans id needed (pic inside)
[Re: ADY]
#781491
01/19/07 04:14 AM
What Engine do you have? AX-5 if it's a 4 cyl, AX-15 if it's a six, they didn't put AX-15's on sixes in wranglers 'till mid 89 but lots of people replaced ba-10s with them it looks like an AX-15.
[Re: JeePete]
#781492
01/19/07 05:29 AM
4.2 I6 .I too think it is the ax15,however it has ATF for fluid in it now, haynes manuel says to use gl5 is this correct?.The tranny has been swapped out with a rebuilt unit but this was done before i purchased it.
[Re: ADY]
#781493
01/19/07 06:00 AM
The Factory Service Manual says use 6.75 pints of API GL5/SAE75W-90 oil in a 4wd version AX-15. I'd get that ATF out of there pronto! The T-case uses ATF. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: JeePete]
#781494
01/20/07 05:19 PM
Arctic circle?, ATF. otherwise I use 80-90 durablend 1/2 synth. The trans will be 100% destroyed w/atf in a normal climate.
SD
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6013 MB (Peak: 0.6656 MB) Data Comp: Off Server Time: 2026-11-02 19:30:42 UTCValid HTML 5 and Valid CSS
