4x4 dash light #781574 01/19/07 04:35 AM
Hugh Offline OP
My 4x4 engagement dash light on my 94' Runner is not working for H4 or L4. What should I check first?
Thanks in advance,
Hugh
94' 4Runner SR5 3.0L, 4X4, 5-speed, 200K
01' Sienna XLE, 105K, auto everything...
91' Ford F-250, 7.3 liter IDI diesel, 5-speed, 170K
Re: 4x4 dash light [Re: Hugh] #781575 01/20/07 04:17 AM
Jake97T Offline
is the actual 4wd engaging? or do you just have a light problem?
Re: 4x4 dash light [Re: Jake97T] #781576 01/20/07 08:19 AM
Hugh Offline OP
Well, the L4 is crawling slow as if engaged, but I don't know about the H4.
I'm not sure how to troubleshoot this one or where to start.
--Hugh
Re: 4x4 dash light [Re: Hugh] #781577 01/20/07 10:33 PM
Jake97T Offline
find some loose dirt around since your fresh out of ice around there and see if your fronts are spinning, the transfer case will still make you crawl slow even if the front isnt engaging, im guessing the light isnt out since it doesnt come on too much compared to the others...
Re: 4x4 dash light [Re: Jake97T] #781578 02/01/07 11:58 PM
Hugh Offline OP
4x4 update: seems that either the electrical signal or vacuum isn't actuating the front drive wheels (not a dash light problem). My guess is that it is a vacuum leak, looking into it as soon as time allows.
--Hugh
Re: 4x4 dash light [Re: Hugh] #781579 02/23/07 12:20 AM
Hugh Offline OP
Update and fix: Ends of the 4x4 vacuum hoses look chewed by mice. Spliced the ends = good to go <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.012s) Memory: 0.6114 MB (Peak: 0.6806 MB) Data Comp: Off Server Time: 2026-11-19 23:57:25 UTC
