longer wheel studs! #781723 01/20/07 04:17 AM
willzrunna96 Offline OP
help i need to get longer wheels studs for my 4runner...being that all toyota 4x4's are the same i figured i post in here..plus you guys rock.....
I had to add small spacers to my hubs to clearence my rims and calipers now i only get 4 turns of the lug on the stud to 80 ft lbs...does anyone know what other studs i could use...so far i have found that the stock knurl is 14.2 and the length is 40mm.. i need about 50mm anyone know anything that would work...i dont care if i need to goto 1/2x20
Re: longer wheel studs! [Re: willzrunna96] #781724 01/20/07 04:55 AM
4Crawler Offline
Re: longer wheel studs! [Re: 4Crawler] #781725 01/20/07 06:34 AM
hey rodger would you happen to know a part number with the right knurl.... also would grinding down the caliper persay be a bad idea
Re: longer wheel studs! [Re: willzrunna96] #781726 01/20/07 06:42 AM
4Crawler Offline
The 610-073 are 2-3/8" long and the knurls press into Toyota hub. Also a 610-144 2-7/8" long. The first works w/ 3/4" spacers on the rea axle and the longer one works on the front w/ 3/4" spacer.
Re: longer wheel studs! [Re: 4Crawler] #781727 01/20/07 06:55 AM
YOU ARE THE MAN....Also i found a stud for a rear or a toyota matrix that has the same knurl as stock toyota studs....same m12 1.5 but the shoulder length is considerably longer. by about 15mm do you think this will make a difference if im using 1/4 spacers?
Re: longer wheel studs! [Re: willzrunna96] #781728 01/20/07 07:09 AM
heres the stud i have found....do you think i have a chance
https://www.dormanproducts.com/cgi-...&vnext=&category_list=:0
Re: longer wheel studs! [Re: willzrunna96] #781729 01/20/07 05:45 PM
4Crawler Offline
You would likely have to measure and see. I know with the longer studs I have, I must run the spacer as the shoulder is too long to allow the wheel to fit without the spacer.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6217 MB (Peak: 0.7123 MB) Data Comp: Off Server Time: 2026-06-17 13:18:07 UTC
