Bleeding Clutch #781787 01/20/07 08:22 PM
1
1tacomaInIt Offline OP
I'm in the process of changing out my clutch master cylinder on my 1996 Jeep Cherokee. However I can't find any way to bleed the clutch system. There doesn't appear to be a bleeder screw on the slave cylinder. Anybody got any ideas?
96' 2door 5spd Jeep Cherokee 6.5" Rusty's lift, 3/4" Coil Spacers, Ford 8.8" Rear, 4.10 Ratio, 35" BFG Mud Terrains, Locked Front, Limited Slip Rear, Roof rack, functional front and rear lights on rack
Re: Bleeding Clutch [Re: 1tacomaInIt] #781788 01/26/07 10:52 PM
1
I ended up buying a master and slave cylinder sealed unit. I did find out from another auto mechanic, that the system on my Cherokee cannot be bled. So if anyone else has this problem, your best bet is to change out the whole thing. Thanks for looking!
Peter
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5876 MB (Peak: 0.6350 MB) Data Comp: Off Server Time: 2026-06-20 17:58:42 UTC
