87 xtra cab headlight wiring harness
#781946
01/21/07 07:15 AM
Recently I read an article about replacing the wiring harness and in some cases after this change you get better performance from your headlights. Is this because the factory harness gauge is too small causing voltage drop. If this is the case would it be worth while making your own harness with heavier gauge wire or just buy a new harness.
Keep the Shiney Side up. Support our troops.
Re: 87 xtra cab headlight wiring harness
[Re: canuck]
#781947
01/21/07 07:37 AM
4CrawlerOffroad has the harness you're looking for here -- Matt
'89 4runner SR5, 3.0, auto (fun) '93 xtra cab, dlx,3.0, 5spd (work truck)
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5891 MB (Peak: 0.6370 MB) Data Comp: Off Server Time: 2026-05-29 15:17:02 UTCValid HTML 5 and Valid CSS
