noise from the heat sheild located behind the engine #782003 01/21/07 06:38 PM
Hackattack Offline OP
Can anyone tell me if they have had a rattle when the engine is a certain RPMs ? I think I have found the location of the noise (between the engine and dash) but when I check the heat shield it seems to be tight? This noise is driving me nuts.
Toyota T100 best truck Toyota ever built "Its so good the frame does not rust in half"
Re: noise from the heat sheild located behind the engine [Re: Hackattack] #782004 01/21/07 07:32 PM
Scott McCrea Offline
That's exactly what mine had. I told my muffler guy about when he was putting a new muffler. He replicated it by beating on the exhaust pipe. Then he stuck a broom handle up in and pressed on the shield quieting the rattle, confirming the location. He tacked a weld on it and it's been fine since. Thank god, cause it was really annoying.
'97 T100, XCab, Auto, 3.4, 175k, 4x4, SnugTop cap, custom over-cap rack.
Re: noise from the heat sheild located behind the engine [Re: Scott McCrea] #782005 01/21/07 09:03 PM
ErikB Offline
Toyota Moderator
A DIY fix is to put a hose clamp around the cracked shield. <img src="/forums/images/graemlins/cheers.gif" alt="" />
http://home.4x4wire.com/erik
Re: noise from the heat sheild located behind the engine [Re: ErikB] #782006 01/22/07 04:30 AM
RichieRich Offline
Is that the noise that sounds like a exaust leak (almost)???? and does it intermitently???
07 Mercedes GL 450
93 Freightliner FL 70 C/C 8.3 cummins, allison auto
96 Toyota T100 4x4 xtra cab v6 5 spd
05 KZ 41kx2 NV Toy Hauler 14'garage 43'of 5r
04 polaris 500 HO 50th year limited
02 polaris 500 HO
51 willys M38
56 Dj
Re: noise from the heat sheild located behind the engine [Re: RichieRich] #782007 01/24/07 01:03 AM
yes it seems to be worse when its cold. When you hammer the gas it goes away but if you push on the gas gently it really rattles
Re: noise from the heat sheild located behind the engine [Re: Hackattack] #782008 01/24/07 04:49 AM
RichieRich Offline
YEA...... I will check that out! I was like what the hail.....
Rich
07 Mercedes GL 450
02 polaris 500 HO
51 willys M38
56 Dj
Re: noise from the heat sheild located behind the engine [Re: RichieRich] #782009 01/28/07 06:06 AM
MisterZee Offline
my heat shield had some broken spot welds. Removed the crossover pipe, and rewelded it.
98 Taco 4WD
Re: noise from the heat sheild located behind the engine [Re: Hackattack] #782010 01/28/07 06:18 AM
CJMT100 Offline
I think I have this problem too, its almost like whistling when really, really cold..and goes away when everything is warmed up.
Re: noise from the heat sheild located behind the engine [Re: CJMT100] #782011 01/28/07 06:08 PM
NYT100 Offline
I put a hose clamp on mine a year ago. Instantly got rid of the noise and it still sounds good- no rattling.
97 T100, 32" BFG/AT, Warn hubs, stock height with Bilstein shocks, Optima battery
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6254 MB (Peak: 0.7112 MB) Data Comp: Off Server Time: 2026-10-22 12:10:31 UTC
