Front wheel bearing race? #782073 01/21/07 10:53 PM
silver94sr Offline OP
hello all,
I am in the process of replacing my front wheel bearings, but for the life of me I can't seem to get the bearing races out of the hub. I have tried pounding them out with no luck and i have also tried a slid hammer w/ reverse claw on the end with no luck. I thought about using a heat gun, but was concerned that I might heat it up to much and warp the hub. Any ideas on how to get the races out of the hub?
Thanks
Chris
1994 Montero SR 101,000 JDM 3.5
2" BL, 2.5" Valley Springs Rear Coils
BFG's 33x12.5 MT
Re: Front wheel bearing race? [Re: silver94sr] #782074 01/21/07 11:57 PM
LandRaider Offline
Those hubs get Super hot due to braking, so I don't think you could hurt them with a heat gun.
Get a punch, and punch them out from opposing sides.
Re: Front wheel bearing race? [Re: LandRaider] #782075 01/22/07 12:04 AM
I think i will try the heat gun on them.
I have tried a hammer and punch, those suckers won't budge at all.
Thanks for the help
Chris
BFG's 33x12.5 MT
Re: Front wheel bearing race? [Re: silver94sr] #782076 01/22/07 12:56 AM
LandRaider Offline
WELL, you're not hitting them hard enough, or your hammer is the wrong size, OR the piece you're hitting is not secured properly.
Hammer, and a brass drift OUGHT to be enough to get them out.
Re: Front wheel bearing race? [Re: LandRaider] #782077 01/22/07 01:33 AM
sparkem Offline
You can bring them somewhere and get them pressed out.
Re: Front wheel bearing race? [Re: LandRaider] #782078 01/22/07 01:36 AM
hit on them from the inner side, the fat part of the race. Each race goes out it's side of the hub.
Re: Front wheel bearing race? [Re: fasteddy] #782079 01/22/07 04:16 AM
DaphneD Offline
IIRC, there might be an edge inside the spindle which can be mistaken for the bearing race if you're not careful. I seem to remember denting it the first time I attempted this procedure. Tap (pound) the bearing race out using a triangular pattern for strike points. That should knock them loose pretty easily.
Re: Front wheel bearing race? [Re: DaphneD] #782080 01/22/07 04:57 AM
All I needed was a bigger hammer they almost jumped out by themselves, j/k. Heated them up a bit and it took a lot of ponding, but they came out.
thanks for comments and help.
BFG's 33x12.5 MT
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6225 MB (Peak: 0.7049 MB) Data Comp: Off Server Time: 2026-06-10 01:42:42 UTC
