Follow-up.. #782092 01/22/07 12:30 AM
RalkClimber Offline OP
Well. New cam, dist, oil pump, dist cap, roto button. Everything went in great... Started it and it ran, but ZERO oil pressure..
Thoughts?
Engine seemed really tight too. <img src="/forums/images/graemlins/confused.gif" alt="" />
Ralk
'97 Jeep Wrangler 2.5L 105k Miles
Recent Replacements: Cam Shaft, Lifters, Push Rods, Distributor, Dist. Cap/button, Plugs, Oil Pump, Oil Sending Unit, Timing Chain/sprokets, and all associated gaskets.
Re: Follow-up.. [Re: RalkClimber] #782093 01/22/07 02:40 AM
JeePete Offline
<img src="/forums/images/graemlins/confused.gif" alt="" /> The oil pump may need to be primed. I'd pull the distributor and rig a suitable driver for the oil pump that I could turn with a drill. Make sure you turn it the right direction if you try this. If there is no oil in the pump it will spin fast when/if it picks up oil you'll know it. Also if there is zero oil pressure the lifters will make a hell of a racket, are they? or are you just going by a bad or disconnected gauge? Did you install new bearings with the cam? Use assembly lube? <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Follow-up.. [Re: JeePete] #782094 01/22/07 03:25 AM
john_luttrell Offline
I use a long common screwdriver that has the handle cut off to prime the pump. Stick it in a drill and it will prime with in a few seconds.
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: Follow-up.. [Re: JeePete] #782095 01/22/07 06:52 AM
yes... the lifters are clacking like crazy... new bearings and assembly grease <img src="/forums/images/graemlins/kewl.gif" alt="" />
I'll try the prime ..
Ralk
Re: Follow-up.. [Re: RalkClimber] #782096 01/22/07 04:22 PM
JeePete Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> Just checking, The new cam should have spun freely when it was installed, I hope your perceived engine stiffness is due to cold weather combined with maybe a weak battery? Good luck! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Follow-up.. [Re: RalkClimber] #782097 01/22/07 05:28 PM
BigJim Offline
Primeing it will also pump up the lifters and fill the ones that are under spring pressure. After primeing it you should have lots less clacking and then in a few seconds all the clacking should stop after starting it.
Re: Follow-up.. [Re: BigJim] #782098 01/23/07 02:42 PM
Priming worked like a charm.. Engine sounds strong.. Haven't got it on the road yet, but i'm looking forward to it. Work is getting in the way of finishing it up <img src="/forums/images/graemlins/barf.gif" alt="" />
Ralk
Re: Follow-up.. [Re: RalkClimber] #782099 01/23/07 03:53 PM
JeePete Offline
Re: Follow-up.. [Re: RalkClimber] #782100 01/23/07 06:24 PM
Great to hear you will be back on the rode soon.
John Luttrell
Re: Follow-up.. [Re: john_luttrell] #782101 01/23/07 06:53 PM
BigJim Offline
Hey ralk....I want to know what the old cam looked like?
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6349 MB (Peak: 0.7580 MB) Data Comp: Off Server Time: 2026-11-01 12:15:46 UTC
