Front wheel suspention kraking noise on Montero SR.
#782301
01/22/07 04:27 PM
This is another problem on my Montero SR 1995. Their is a cracking noise in the front wheel suspension; when you do not use the SUV for a day and you start it up and move it the front wheel suspension makes a cracking noise someone told me that could be the bushings that they are not tide enough and go through. Is that right?
Re: Front wheel suspention kraking noise on Montero SR.
[Re: arm755]
#782302
01/22/07 05:11 PM
There are a number of grease fittings on the driveline. Has anyone ever greased them?
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5873 MB (Peak: 0.6352 MB) Data Comp: Off Server Time: 2026-06-13 10:49:06 UTCValid HTML 5 and Valid CSS
