Water in oil #782369 01/22/07 11:25 PM
Kona Offline OP
I lent my truck out to a friend a week ago and when I got it back I found the coolant level very low and slight signs of oil in the water. First let me say that I'm not trying to lay responsibility on my friend but I think it might be worth noting since it's the first time in a year that someone used the truck daily as primary transportation. Anyhow, on with the story, I found one of the lower hoses to have a small leak when hot so I changed all of the hoses(they were pretty old anyway) and checked compression. Dry compression is between 150 and 160 on all cylinders, I'm not blowing white smoke, and three of the plugs looked good while the number one plug had an excessive gap and showed signs of overheating. I also noticed water spray on the hood in line with the belts after a trip to the parts store and I'm wondering if this can all be caused by a bad water pump? Can a damaged water pump lead to water in the oil or is it more likely a sign of a damaged timing chain cover? How likely is it for a head gasket to become damaged between the oil and coolant galleys but not at the cylinders?
Back in the West!
Re: Water in oil [Re: Kona] #782370 01/22/07 11:52 PM
TimsToyo Offline
When you changed the hose(s) did you burp the system for air?
'86 Toyo 4wd
'04 600RR
Re: Water in oil [Re: Kona] #782371 01/23/07 01:41 AM
fourwd1 Offline
How about giving us the basics, like what engine do you have ?
If its a 22R/E it could be a loose timing chain has worn through the timing chain cover. You wouldn't se it in the exhaust (white smoke).
Or a blown head gasket (you might see it in the exhaust).
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Water in oil [Re: fourwd1] #782372 01/23/07 01:45 AM
Kona Offline OP
Yeah I burped. 22re with 210k and 80k on the timing chain(and cover). No rattles out of the ordinary.
Back in the West!
Re: Water in oil [Re: Kona] #782373 01/23/07 02:15 AM
OOP'S Offline
What are the signs of "slight signs of oil in the water"? Elaborate please.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Water in oil [Re: OOP'S] #782374 01/23/07 02:46 AM
Kona Offline OP
Not a frothy mess, but milk chocolate color when drained and very small amount of foam on the oil cap.
Back in the West!
Re: Water in oil [Re: Kona] #782375 01/23/07 04:34 AM
kewlynx Offline
Sounds like he went thru a water hole. Get about 3 beers in him and ask him if he went wheeling with the truck.
**ubi apis- ibi salus**
Re: Water in oil [Re: Kona] #782376 01/23/07 05:29 AM
OOP'S Offline
Small amount of foam on oil cap is normal, comes from short trips and condensation forms and is not burned off from not running at operating temperature. Now the milk chocolate colored oil is another story. If it is running OK I would drain and flush it, do an oil and filter change to see if it comes back. If it does you have a problem, if it does not, grab your "friend" by the short-hairs until he fesses up to what he did with your rig
David Fritzsche
Roseville, CA
Re: Water in oil [Re: OOP'S] #782377 01/23/07 07:07 AM
half_fast Offline
Oil will saturate with water from moisture in the air if it sits. Change the oil and drive it.
Michael J. Carsner proud driver of "Aint Pretty"
37 boggers, 571 gears, Detroit+Lock-Rights, 20R stage 1 LC Engineering head on 22R motor.
MUD!!! Its whats for dinner!!
Re: Water in oil [Re: kewlynx] #782378 01/24/07 02:20 AM
Stevie Offline
Don't know about Arizona, but back in Nebraska, it'll take at least 6! <img src="/forums/images/graemlins/notooth.gif" alt="" />
'80 4X4 Longbed
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.009s) Memory: 0.6374 MB (Peak: 0.7612 MB) Data Comp: Off Server Time: 2026-07-16 03:41:30 UTC
