bigger tires on stock montero #782404 01/23/07 02:32 AM
I'm trying to find out what are the biggest tires I can put on my stock 2002 Montero XLS(265 x 70 x r16 currently)! Please advise if someone knows or if someone has done this succesfully.
Re: bigger tires on stock montero #782405 01/23/07 03:19 AM
with the right rim set you can run a 33"x12.5" unless you're talking about a montero sport then you're looking at like a 32"x9.5" i assume you mean biggest tire without lift
Re: bigger tires on stock montero #782406 01/23/07 04:42 AM
icysyrup Offline
285/75R16s <img src="/forums/images/graemlins/kewl.gif" alt="" />
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Re: bigger tires on stock montero [Re: TOASTY] #782407 01/26/07 04:45 AM
Stock rims for now, I actually like them. Are you talking about different rims or will stock work. Also, local dealer said the biggest I could go without rubbing was 265x75xr16(currently 265x70xr16). I think the dealer was just being too cautious.
Re: bigger tires on stock montero [Re: icysyrup] #782408 04/16/11 10:27 AM
Schmidty Offline
Toasty said you could Could fit 33"x12.50" your saying 32.83"x11.22"? which one will fit with a two inch lift?
2002/Mitsubishi/MonteroXLS
Re: bigger tires on stock montero [Re: Schmidty] #782409 04/16/11 02:28 PM
dougl3nc Offline
33x12.5
1989 Raider SWB Auto 3.0L...It's ALIVE!
Currently on a shakedown cruise...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6083 MB (Peak: 0.6731 MB) Data Comp: Off Server Time: 2026-06-17 04:17:13 UTC
