third members #782462 01/23/07 03:53 AM
kc85 Offline OP
are third members interchangeable front to rear
Re: third members [Re: kc85] #782463 01/23/07 04:06 AM
YOTA88 Offline
whay year?
they are interchangeable unless you have an IFS front suspension.
SAS88TOY, caged, lockered, Longfielded, etc. etc. etc. blah blah blah!!!
2005 Tundra Quadcab.
Re: third members [Re: kc85] #782464 01/23/07 04:06 AM
4Crawler Offline
On the '85 and earlier, yes:
- http://home.4x4wire.com/erik/diffs/#types
Re: third members [Re: 4Crawler] #782465 01/23/07 04:07 AM
kc85 Offline OP
how are they, does't one spin backwards
Re: third members [Re: kc85] #782466 01/23/07 04:09 AM
4Crawler Offline
Yep, front diff runs in reverse going forward. Put it in back and it'll run forward.
Re: third members [Re: 4Crawler] #782467 01/23/07 04:11 AM
kc85 Offline OP
i'm new sorry if i sound stupid, so does one run on the coast side of ring gear, and isn't that weaker
Re: third members [Re: kc85] #782468 01/23/07 04:13 AM
4Crawler Offline
Yep, unless you get a high-pinion 3rd member w/ reverse cut gears:
- http://www.4crawler.com/4x4/4R_TechInfo.shtml#ReverseCutGears
Re: third members [Re: 4Crawler] #782469 01/23/07 04:15 AM
kc85 Offline OP
last one, why can't modify housing turn third upsidedown and have high pinion, thanks for your answers
Re: third members [Re: kc85] #782470 01/23/07 04:59 AM
4Crawler Offline
Firstly, it'll run backwards (in either axle).
Secondly, won't oil properly, nothing to sling/pump oil up the the high pinion gear, you'll need to overfill the axle to keep it oiled.
More info: http://www.pirate4x4.com/forum/showthread.php?t=545699
Re: third members [Re: kc85] #782471 01/24/07 12:41 PM
Ganoid Offline
Turning the third over is easy its getting the pinion offset to move to the other side of the ring gear so you can flip the carrier. The casting just wont work due to the pinion offset.
90 Xcab V6
3.0 Rebuilt/Balanced
P/P w/OS valves
Downey Hdrs,Jacobs Ign
5.29's,Tru Trac+Lockright
4"TG SAS+Rear Kit on 35's
(DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />)
www.performancecylinderheads.com
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6439 MB (Peak: 0.7631 MB) Data Comp: Off Server Time: 2026-06-20 18:15:02 UTC
