Re: Rebuilding a 22RE [Re: 87Toy4x4] #782534 03/01/07 12:22 AM
Staceman Offline
Or you can just use your old cover, in the cabinet of the garage, that has the wear marks thru 'em <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
C'mon, you know you got one. A paper weight, AND a template.
Re: Rebuilding a 22RE [Re: Staceman] #782535 03/01/07 03:52 AM
bodo Offline
The Brother PTouch laminated label maker works wonders. The labels stick to all the hoses and wires even after your nasty fingers have been all over them and the labels don't soak up oil like masking tape and sharpie. People laugh at me because a leave all the little white labels still attached but you never hear me asking where does this go?
X2 on digi pictures, you can print them, blow them up, write on them with sharpie, and then thumbtack them on a board for quick reference.
Re: Rebuilding a 22RE [Re: kewlynx] #782536 03/20/07 04:02 AM
Bevoman Offline OP
Thanks to all for the great advice! I got started pulling everything apart two days ago and am almost ready to disconnect the clutch and tranny. I'll keep yall posted and post a pic now and then.
Hook 'Em
Re: Rebuilding a 22RE [Re: Bevoman] #782537 03/23/07 02:29 AM
Bevoman Offline OP
The FSM says to remove the bond cables on the RH side and rear of the engine. I don't see anything more to remove except the fuel line and the clutch slave. Can anyone tell me what a "bond cable" is and where to find it?
Thanks,
Bevoman
Hook 'Em
Re: Rebuilding a 22RE [Re: Bevoman] #782538 03/23/07 09:14 AM
Davepet Offline
Probably the ground strap that runs from the head to the firewall. There are lots of redundant grounds on these machines, so yours may have been removed by a PO.
Dave
Re: Rebuilding a 22RE [Re: Davepet] #782539 03/24/07 07:26 AM
Bevoman Offline OP
Makes sense . . . there is one such wire that I overlooked. Thanks Dave!
Hook 'Em
Re: Rebuilding a 22RE [Re: Bevoman] #782540 03/24/07 08:01 AM
Davepet Offline
No problem, that's what the forum is for.
Re: Rebuilding a 22RE [Re: Davepet] #782541 03/24/07 09:12 PM
kyle-22r Offline
Dave
just don't let it get in the way upon reassembly and mash the wire down underneath a rocker arm boss like i did! <img src="/forums/images/graemlins/lol.gif" alt="" />
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Rebuilding a 22RE [Re: kyle-22r] #782542 03/26/07 03:14 PM
Red_Chili Offline
Toyota Section Staffer
We pulled Bevoman's motor yesterday after a fine lunch of sammys and Smithwick's. The starter made quick work of the crank bolt, and actually remembering to remove the starter made quicker work of removing the motor... <img src="/forums/images/graemlins/lol.gif" alt="" />
The PO didn't exactly take real good care of this truck! Now the nasty greasy work begins. I think he'll need a case of brake cleaner!
-Bill
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6291 MB (Peak: 0.7330 MB) Data Comp: Off Server Time: 2026-10-24 19:59:23 UTC
