?? Max tire size for stock Tundra ?? #782564 01/23/07 02:20 PM
Rockfish Offline OP
The classic question:
What is the max tire size that will work on a stock '05 Tundra Access Cab 4WD??
...with stock 16: steel rims. ...with NO rubbing
Willing to switch to basic steel rims with a different backspacing if that is needed.
This is for a daily-driver rig with occasional mild wheeling. My lifted '95 Taco is my wheeling rig of the past 10 years, but the Tundra is new to me.
TIA
Re: ?? Max tire size for stock Tundra ?? [Re: Rockfish] #782565 01/23/07 11:08 PM
Jake97T Offline
Crickets churping in the background...( <img src="/forums/images/graemlins/rolleyes.gif" alt="" />) What size tires are you working with now? As far as backspacing goes usually the stock aluminum rims youve got now have more to offer than a steel wheel. Id go with a 265/70R16 (TRD size tires), or a 265/75R16...a 285 would look great but would need some lift in front.
Re: ?? Max tire size for stock Tundra ?? [Re: Jake97T] #782566 01/23/07 11:11 PM
Rezkid Offline
My dad has 265x75R16's on the stock steelies on his '03 Access Cab, they fit fine no rubbing or anything like that
'80 Isuzu LUV, 3" BL, cranked t-bars, small tires and not alotta power
'92 Rodeo...work in progress
Hmmmm...DIRT!!!
Re: ?? Max tire size for stock Tundra ?? [Re: Rezkid] #782567 01/24/07 12:33 AM
ErikB Offline
Toyota Moderator
My understanding is that is about as big as you can go on the Tundra's before you start needing lift for tire clearance.
http://home.4x4wire.com/erik
Re: ?? Max tire size for stock Tundra ?? [Re: ErikB] #782568 01/24/07 06:31 PM
Rezkid Offline
That would be my guess as well. Like I said they fit fine and don't rub at all offroad (my dad's work truck, it sees pretty rough conditions at least 4 days a week) With 285's I would imagine that you would run into some rubbing issues and would need a 2" lift to clear things
Hmmmm...DIRT!!!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6049 MB (Peak: 0.6695 MB) Data Comp: Off Server Time: 2026-06-23 01:20:20 UTC
