Grease Talk - Moly or Lithium
#72074
02/10/03 02:22 PM
I did a quick search but didn't find what I was looking for.
I know that we are supposed to use the correct grease for the correct application, but which grease goes where and why?
From my quick research I have concluded:
Moly grease is so named because it contains molybdenum disulfate which helps reduce friction. Moly grease is usually grey or black in color.
Lithium grease sounds very vague. "The term Lithium Grease can be slightly misleading as the lithium content is actually the thickener used to thicken the oil content to make it a grease as opposed to an oil." From what I have seen these tend to be colored red or green.
So where on my Runner requires the added protection of Moly and why not just use moly everywhere..? After all moly grease does contain lithium as a thickening agent anyway..?
Thanx,nj
1996 Hilux Surf KZN185, 3.0L 1KZ-TE Turbo Diesel, 5-Speed BFG AT's 265 70R16, SAW's, 2.5 Cornfed & OME N86C shocks, Sway Bars Removed, Rear Diffbreather. Webshots Pictures
Re: Grease Talk - Moly or Lithium
#72075
02/10/03 02:46 PM
Toyota Moderator
I've been using moly grease on all the driveshaft fittings... The diagram below shows specificly where the moly is called for.. on sliding joints such as the double cardan and the slide yokes..
<img src="http://personalpages.bellsouth.net/d/a/dandeman/photos/driveshaft.jpg" alt=" - " />
I use Mobil moly grease <img src="http://personalpages.bellsouth.net/d/a/dandeman/photos/molygrease.jpg" alt=" - " />
2000 4Runner,V6,Auto,31's, Sliders, Skids, On-Board Air, Air Shocks Related Interests: Welding, Ham Radio, Road Tripping (Blue Highways), High End Video/Audio Systems
#72076
02/10/03 05:52 PM
As far as I've ever seen or read, the only place you'd use lithium grease is on your steering knuckles. The only lithium grease I've seen is white and apparently it does better in severe temp conditions than moly. But I use moly everywhere, all around, including the steering knuckles. I've had no (knock on wood) problems.
Al
#72077
02/10/03 07:09 PM
I use synthetic moly grease everywhere incl. steering knuckles. If it's good enough for wheel bearings/prop shafts, it's good enough elsewhere. No problems yet.
'86 4Runner: ARB winchbar, Kaymar, e-codes, OME lift, RR diff lock, FR truetrac, sound stream a/d/s audio, recaros. '03 LX470: ARB sahara bar, Kaymar, HID's, ART cryo'd/slotted rotors, Stoptech SS hoses. '01 Prelude SH '00 CRV
#72078
02/10/03 08:46 PM
How about in the CV's? What are you supposed to pack the boots with? I used some high temp red lithium grease, but i didn't remove the old grease first. Will i have trouble or did I do good? <img border="0" alt="[Hillbilly]" title="" src="graemlins/notooth.gif" />
#72079
02/11/03 08:22 PM
Toyota Moderator
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by kyoso23: <strong>How about in the CV's? What are you supposed to pack the boots with? I used some high temp red lithium grease, but i didn't remove the old grease first. Will i have trouble or did I do good? <img border="0" alt="[Hillbilly]" title="" src="graemlins/notooth.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I've had difficulty using anything other than factory supplied grease with CV's..
Bought a rebuild kit (boots and grease) from one of the el cheapo mass market auto parts store.. and CV's starting popping and binding from the crappy grease ... Parked it right away, tore it down and rebuilt using dealer supplied kit, and no further problems.. This was on a Subaru.
I could see some minor spalling where the junk grease just wasn't doing the job.. CV grease seems to be some really special stuff given the sliding contact and heavy loading inside a CV. <small>[ February 11, 2003, 02:26 PM: Message edited by: Dandeman ]</small>
