Warner manual hubs #783017 01/24/07 11:54 PM
Hackattack Offline OP
Has anyone bought a set of Warner manual hubs (part#28761) and installed them on their T100 that has the auto hubs? Warner is telling me that I need the spindle nut kit (part#29918) but some of the articles on this forum suggest that I do not need any kits, just bolt them on?
Toyota T100 best truck Toyota ever built "Its so good the frame does not rust in half"
Re: Warner manual hubs [Re: Hackattack] #783018 01/24/07 11:59 PM
Jake97T Offline
T100 did not come with "auto" hubs, they're drive flanges, no kit needed, although i suggest you get some ASIN hubs on ebay or junkyard, because the warn hubs tend to shear the studs/centering pins off, they dont turn as smooth, stick out alot further and are not as strong...you can pick some up online for $50, make sure you get the cone washers with them, these help keep the hub tight.
Re: Warner manual hubs [Re: Jake97T] #783019 01/25/07 12:59 AM
NYT100 Offline
I've had a pair of Warn hubs on my truck for the last 5 years with no problems. They do stick out a lot farther than the Aisin hubs. Either one will work, and the Aisins are available used. I see them in the for sale section every couple of months.
97 T100, 32" BFG/AT, Warn hubs, stock height with Bilstein shocks, Optima battery
Re: Warner manual hubs [Re: NYT100] #783020 01/25/07 02:21 AM
CJMT100 Offline
You want warn premium hubs they are built much better, but aisins are overall the best.
Re: Warner manual hubs [Re: Hackattack] #783021 01/25/07 03:09 AM
surlynkid Offline
he does not need the cone washers. he has them on his drive flanges.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Warner manual hubs [Re: Hackattack] #783022 01/25/07 04:32 AM
garym Offline
I've had the Warn's on for 3 years now with no problems. They go on quick and easy once you get the cone washers off the old ADD system. Also, no hassels with the cone washers anymore.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: Warner manual hubs [Re: garym] #783023 01/25/07 05:39 AM
Jake97T Offline
forgot that the drive flanges have them... <img src="/forums/images/graemlins/notooth.gif" alt="" />, my warns (premium) wouldnt stay tight, used them for 3 years, sheared my centering pins off.
Re: Warner manual hubs [Re: Jake97T] #783024 01/25/07 07:49 AM
CJMT100 Offline
Just bad luck I guess Jake, mine are always tight-I check them like monthly to make sure...
Loctite mighta helped ya
Re: Warner manual hubs [Re: CJMT100] #783025 01/25/07 04:56 PM
ErikB Offline
Toyota Moderator
Jake's experience with the Warn's is more common than not, especially if you use 4wd very often. I've seen it on all the Toyota's I've worked on that had them (at least 4 that I can think of), including my own so I know they were maintained halfway decently. I swapped them out for Aisins.
The factory hub retention design (using cone washers) is far superior, and doesn't NEED any maintenance. Factory Aisin hubs are definitely the best way to go for a Toyota. Yes, the cone washers can be a pain to remove if you don't use anti-seize on them, but they were designed that way on purpose! This is why they use the same retention system on all-important steering components on Dana and Toyota axles (and probably others).
I like the Warn Premiums on my D44, but they don't have any bolts to loosen up. <img src="/forums/images/graemlins/notooth.gif" alt="" />
http://home.4x4wire.com/erik
Re: Warner manual hubs [Re: ErikB] #783026 01/25/07 05:01 PM
Jake97T Offline
The metal seemed fairly soft on the warn hubs, although they're tight one day, the next time you put it in 4wd they loosen up again...
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6345 MB (Peak: 0.7577 MB) Data Comp: Off Server Time: 2026-10-21 18:58:29 UTC
