Engine Life #783104 01/25/07 03:28 AM
so i have a 96' t100 with the 3.4L in it.(Bone stock for now)i jsut hit 225,000 miles, i burn NO OIL, and NO ANTIFREEZE.also all my major gaskets are sealed tight. head gasket,valve cover, manifold. does anyone know what the expectancy life of an engine like this?
T100_Trucker. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Engine Life #783105 01/25/07 06:11 AM
ErikB Offline
Toyota Moderator
Mine is similar, but burns a little bit of oil (not any more than it ever has though). I see no indication that these things aren't going to last another several hundred thousand miles. <img src="/forums/images/graemlins/smile.gif" alt="" />
http://home.4x4wire.com/erik
Re: Engine Life #783106 01/25/07 04:53 PM
jmoser Offline
With proper maintenance and no abuse the 3.4 should go >500K without major component failure.
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
Re: Engine Life #783107 01/25/07 08:27 PM
Squeezer99 Offline
i've got 247k miles on mine, but I've got the 3rz-fe.
Re: Engine Life #783108 01/28/07 06:04 AM
MisterZee Offline
I have almost 200k on mine, bought it with 175k on it. The only thing that bugs me is the oil pressure drops pretty low on the meter when it warms up. It purrs and pulls though.
98 Taco 4WD
Re: Engine Life #783109 02/03/07 07:02 AM
thecat Offline
My original motor died at 156k. It threw a cam threw the front of the head. I beleave it to be because the original owner didn't change the oil very often. But the new motor has run great ever since.
Toyota master
Re: Engine Life [Re: thecat] #783110 02/04/07 05:31 AM
RichieRich Offline
Mine just turned 132k, it has develpoed a bit of an oil leak at what seems to be the rear main. also have the tapping of a lifter I suppose should get that done soon.
Rich
07 Mercedes GL 450
93 Freightliner FL 70 C/C 8.3 cummins, allison auto
96 Toyota T100 4x4 xtra cab v6 5 spd
05 KZ 41kx2 NV Toy Hauler 14'garage 43'of 5r
04 polaris 500 HO 50th year limited
02 polaris 500 HO
51 willys M38
56 Dj
Re: Engine Life [Re: RichieRich] #783111 02/04/07 07:00 AM
CJMT100 Offline
Honestly I have about 60k now, its a reman from yota thanks to the PO. But the trans has 189k..
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6179 MB (Peak: 0.6942 MB) Data Comp: Off Server Time: 2026-07-17 02:16:44 UTC
