Whats max tire under cranked T-100? NEED To know ASAP #783303 01/25/07 04:34 PM
sasnydley Offline OP
I have 33x10.5x15s on my montero and might buy a 95 T100 but I want to know if my tires will squeeze in until I could stick a lift under. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Oh It's a 4x4.ext cab
Re: Whats max tire under cranked T-100? NEED To know ASAP [Re: sasnydley] #783304 01/26/07 09:02 PM
the stock hieght on the T100's are ok for 31" but u might want to consider at least a 2-3" lift of some kind. for that reason u can clear the front bumper.
Re: Whats max tire under cranked T-100? NEED To know ASAP [Re: sasnydley] #783305 01/26/07 09:49 PM
santacruzT100 Offline
If u add Sway-away-torsion bars and crank them...u can fit the 33x10.50...here's a pic for u of my T with only a cranked in sway away torsion bar and 285/75r16(33x11.50) here's 2 pictures( big enough that u can see)
1)[Linked Image]
2) [Linked Image]
p.s. There is minor rubbing when fully stuffed and turned...nothing serious though..What backspacing do u have on your wheels??
White '95 T-100 dx 4wd. Auto.
3.4l v6 w/K&N air filter
285/75r16 BFG's Mud on 16x8 American Racing black Fuel wheels.
Sway-a-way torsion bars, soon to add rancho 9000x
Re: Whats max tire under cranked T-100? NEED To know ASAP [Re: sasnydley] #783306 01/26/07 10:02 PM
wsquaredodie Offline
Running 256/75 R16's on 03 Tundra rims. Under full turn, full front end compression I get a light rub on the splash shield hanging off the inner fender well in front of the a A frame. Rarely happens. The height difference actually reduces approx 10% to the odometer / speedometer readings. 55 indicated is actually 60+ mph. Actually improves mileage a bit as the 55 mph rpms are down about 200.
trafdlo
Re: Whats max tire under cranked T-100? NEED To know ASAP [Re: wsquaredodie] #783307 01/27/07 03:31 AM
CJMT100 Offline
32x11.5 without rubbing-you may need to remove the mud flaps though.
33" and above require you to lift at least 1" and or beat the weld at the fender.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6053 MB (Peak: 0.6656 MB) Data Comp: Off Server Time: 2026-05-29 17:25:09 UTC
