Steering stablizer Rancho 5000 #784037 01/28/07 06:06 AM
I bought a steering stablizer on Ebay and it came with a threaded shaft on both ends. No way it will fit without a set of special brackets. Anyone install one of these on a 1991 IFS truck and have pictures of the brackets. I can fab some up but was wondering what Rancho did for brackets.
Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Steering stablizer Rancho 5000 #784038 01/28/07 03:12 PM
Stevie Offline
I don't know about a '91, but I've got one on an '80. It's a piece of angle iron cut to be held on by 2 u-bolts on the steering rod, and having a hole on the other face to attach the stablizer. If you send me your email address, I'll send you some pics (haven't figured out how to do it here) <img src="/forums/images/graemlins/baby.gif" alt="" />.
'80 4X4 Longbed
Re: Steering stablizer Rancho 5000 #784039 01/28/07 05:12 PM
Marc91runner Offline
You'll need the Rancho Steering Stabilizer Bracket kit # RS5573.
I chucked my Rancho because it needed the bracket and got one that fit in the original location.
'91 4Runner SR5 V6 4X4 Auto, A/C (self installed)
4.56, 31x10.5x15 Nokian Vatiiva's
Re: Steering stablizer Rancho 5000 [Re: Marc91runner] #784040 01/28/07 05:41 PM
87Toy4x4 Offline
im not sure if this is a universal pic or not but i found this on google. the pic is small but you can see what the bracket looks like.
Re: Steering stablizer Rancho 5000 [Re: 87Toy4x4] #784041 01/28/07 05:49 PM
Stevie Offline
That's mine, in the top example! Works very well, no binding, hindering, or rubbing.
'80 4X4 Longbed
Re: Steering stablizer Rancho 5000 [Re: Stevie] #784042 01/28/07 08:40 PM
Jake97T Offline
one bracket attached to the steering linkage with the u-bolts, the other end is a long plate which bolts to the inside of the frame rail using the idler arm bolts, the kit supplies longer bolts...i have that setup, works great but im considering ditching it for one that goes in the stock location as well.
Re: Steering stablizer Rancho 5000 [Re: Jake97T] #784043 01/28/07 08:57 PM
DRTDEVL Offline
The one I have is similar to the first one, but the other end is a bracket to the lower control arm.
Came with longer bolts to go through the control arm.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6133 MB (Peak: 0.6906 MB) Data Comp: Off Server Time: 2026-06-09 21:57:54 UTC
