My throwout bearing is toast,.... How much????
#784224
01/29/07 03:31 AM
How much should i look to pay? I mean this thing is going to go anytime now. <img src="/forums/images/graemlins/cheers.gif" alt="" /> 87 pickup 22re 5 spd.
Re: My throwout bearing is toast,.... How much????
[Re: Omega Supreme]
#784225
01/29/07 03:40 AM
IIRC, it'll run you bout $20-$30 for the bearing. i think i paid like $37 for a centerforce throwout bearing when i did a clutch job on my rig a couple of years ago. the price could be more by now but i'm sure someone who has done one recently will chime in.
SAS88TOY, caged, lockered, Longfielded, etc. etc. etc. blah blah blah!!! 2005 Tundra Quadcab.
[Re: YOTA88]
#784226
01/29/07 03:50 AM
how much to have someone else do it?
[Re: Omega Supreme]
#784227
01/29/07 03:52 AM
How do you know it's the bearing? Just curious <img src="/forums/images/graemlins/cyclops.gif" alt="" />.
'80 4X4 Longbed
[Re: Stevie]
#784228
01/29/07 03:58 AM
well an educated guess. It sounds like something rolling around when i am at idle. Push the clutch in and it goes away. When is 1st through 4th its also loud, it sounds like a rumbling. its pretty loud!!!
[Re: Omega Supreme]
#784229
01/29/07 06:18 AM
Hi, this is not likely to be a throwout bearing problem. It is far more likely to be a transmission problem. Provide a more detailed description of the noise. If it sounds like an old roller skate, it likely that the mainshaft bearing is worn. The noise you describe could also be a loose flywheel.
Doug Portland OR 80 4x4
[Re: dougcl]
#784230
01/29/07 06:40 AM
its a loud rumbling,i really dont know how to explain it. It has gotten worse. I need to take it, i dont know the first thing about trannys. Its the loudest in 1st and second gear. It sounds like rocks in a trash can. The only time it is quite is when it is 4th or 5th or the clutch is in.
[Re: Omega Supreme]
#784231
01/29/07 06:47 AM
Input bearing is going.I found a good used trans.Replacing it this week. Having someone do it for you and the replacement cost will be substantial.
1985 SR5 4Runner eLocked with Carter Lock 4.7:1 single case Davez Offroad twin stick
[Re: Omega Supreme]
#784232
01/29/07 08:32 AM
It sounds like something rolling around when i am at idle. Push the clutch in and it goes away. Nope, not likely the throwout bearing, unless the clutch is miadjusted, throw out bearings only spin when the clutch pedal in pushed in. X2 on the input bearing being the most likely cause. Dave
[Re: toyrunner]
#784233
01/29/07 04:50 PM
This sounds like the Input Shaft Bearing in your tranny. You may what to check and make sure you have enough fluid. If it is your tranny you will notice that 5th gear maybe the loudest and 4th gear may be the quietest. Do a quick search on input shaft bearing or tranny rebuild. Here is a link to a D.I.Y. rebuild. Tranny rebuild Good luck....
1991 FJ 80 Land Cruiser for fun. 1998 GS300 for the wife 1998 GS400 for me 1991 Supra SOLD 1986 4Runner 335k miles-22re EB inside.SOLD
