Page 3 of 3 1 2 3
Re: how to improve brake performance? [Re: allochris] #784472 03/03/07 03:40 AM
4Crawler Offline
Sure, lower the sensing arm on the LSVP to lessen rear brake bias.
Re: how to improve brake performance? [Re: 4Crawler] #784473 03/03/07 05:26 PM
ErikB Offline
Toyota Moderator
Pad/shoe wear is not a good indication of brake bias.
The method I've usually heard for checking bias is to find a wet or gravel road, get up to speed and then hit the brakes hard. If the rears lock up first, you have too much bias to the rear. If you can't get the rears to lock up, the add more rear bias. Adjust so that fronts lock up just before the rears.
You just want to set it up so that the rear doesn't lock up first because then it will try to swing around on you, like when yanking the e-brake. <img src="/forums/images/graemlins/lol.gif" alt="" />
http://home.4x4wire.com/erik
Re: how to improve brake performance? [Re: allochris] #784474 03/04/07 02:31 PM
wr250 Offline
if the brake lining is cracked all the way through (or even more than just a heat crack) just replace them. the price of rear brake shoes is not worth the sudden failure if the shoes come apart (brake lockup or worse, no brakes at all)
replaced the worn out wheel cylinders then drive it. if it is not ok then adjust the proportioning valve as needed.
85 runner -dual cases, headlight harness, 34" TSL's
86 toy buggy getting sas'ed with a 14 bolt rear - 8.5" 10 bolt front (this will go away when i find a 60)
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.5999 MB (Peak: 0.6703 MB) Data Comp: Off Server Time: 2026-07-09 16:50:35 UTC
