hi-lift problem?! #784538 01/30/07 04:27 AM
willzrunna96 Offline OP
just bought a new 48" cast/steel hi-lift i have noticed that you need to keep upward pressure and the lever that is used to engage the jack and disengage it in order for the jack to lift something...is this normal?
Re: hi-lift problem?! [Re: willzrunna96] #784539 01/30/07 04:31 AM
87Toy4x4 Offline
sometimes they stick, i usually kick the lever on mine to get it to engange/disengage lol. im still mad at that thing for cutting my head open while i was using it as a come along haha. be careful.
Re: hi-lift problem?! [Re: willzrunna96] #784540 01/30/07 05:28 AM
kewlynx Offline
Here's yer next project
http://www.4x4wire.com/toyota/minutemods/hilift_base/
Yep, x2 on be careful. Dem dayem things is widda-makers.
**ubi apis- ibi salus**
Re: hi-lift problem?! [Re: 87Toy4x4] #784541 01/30/07 05:32 AM
OOP'S Offline
Spray it down with some WD-40!!!! Be careful, hi-lifts can kill or hurt you bad. I carry lengths of chain with hooks that I wrap around the frame and axle so I do not have to jack it up so high. That and my rig has so much flex that the hi-lift will not lift the wheels off the ground when all the way up.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: hi-lift problem?! [Re: willzrunna96] #784542 01/30/07 02:11 PM
Dandeman Offline
Toyota Moderator
When you set the lever to make it jack down, when it gets to where that is no load on it, it will then release and slide the rest of the way down the post.. That's normal....
I presume from your cast/steel description, that yours is a genuine HiLift company built jack.. Given how dangerous these things can be, I personally would not use any of the many knockoff unbranded versions around...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6055 MB (Peak: 0.6700 MB) Data Comp: Off Server Time: 2026-06-17 10:44:54 UTC
