stall!!!!!! #784556 01/30/07 06:19 AM
poorboy4x4 Offline OP
hmmm..... I recently installed a weber 32/26 w/ electric choke. jeep runs awsome but today it stalled twice on me. on on the freeway doing about 80mph just for a brief second. i pressed on the clutch and slammed on the gas, jeep turned right back on almost like 1/2 a second after. and later this evening it stalled at a light. i turned the key without stepping on the gas and it turned over but no go.... i slammed on the gas and it slowwwly chugged back on. im thinking its the electric choke? i had to use a different lead for the hot wire. does anyone else have a clue as what it might be? oh yah... 88 jeep wrangler 4.2 and yes I already replaced the inline fuel filter today... thanks <img src="/forums/images/graemlins/drunk.gif" alt="" />
88 YJ, 4.2L, WEBER 32/36, On 33" Dunlop Mud Terrain, 4.10 ratio, tru-trac locker in dana 35...
Re: stall!!!!!! [Re: poorboy4x4] #784557 01/30/07 04:54 PM
BigJim Offline
Did you do the dist bypass when installing the new carb? If not your timing is fuxed!
Did it backfire? If not then it is prolly fuel related. the pump or filter.
Re: stall!!!!!! [Re: BigJim] #784558 02/02/07 07:28 AM
Yeah my timing was waaaaaaaaaayy off. thanks JIM
Re: stall!!!!!! [Re: poorboy4x4] #784559 02/02/07 05:33 PM
BigJim Offline
PB you did NOT ANSWER the question!!! DID you or did you NOT do the nutter bypass to the dist??? Please answer directly!!!
Re: stall!!!!!! [Re: BigJim] #784560 02/06/07 08:18 AM
Yes I did do the nutter by pass on my yj, damn things gettin like 13.5 mpg now, thats about as much as I think ill ever get <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: stall!!!!!! [Re: poorboy4x4] #784561 02/06/07 10:28 PM
BigJim Offline
Go take the vac off of the dist and check the timing again.. Might just have slipped some.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6092 MB (Peak: 0.6788 MB) Data Comp: Off Server Time: 2026-06-07 07:06:55 UTC
