Engine Swap Question #785501 02/01/07 04:53 PM
n2dp Offline OP
Is it possible to take the 2.5L 6G73 FWD engine out of my 1996 Stratus and put it in my 1988 Raider?
1988 Raider, 2.6L (Weber carb, PaceSetter header, Centerforce D/F clutch, 5-Speed M/T, 33X12.50 Pro Comp M/T, 15X8 US Wheel 97 Series)
3" Body Lift
Re: Engine Swap Question [Re: n2dp] #785502 02/01/07 05:44 PM
LRJ4x4 Offline
Not possible, or should I say not cost effective <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Engine Swap Question [Re: LRJ4x4] #785503 02/01/07 05:50 PM
n2dp Offline OP
Thanks. I was going to get rid of my wife's old Stratus and had a thought. I will just send it to the yard.
3" Body Lift
Re: Engine Swap Question [Re: n2dp] #785504 02/01/07 05:55 PM
Yes it can be done, but it is not real easy. If your Monti were a 3.0 it would be set for an injected engine.
What you will run up against is getting and swapping in a transmission from a V6, if yours was an automatic this would be straight forward.
You then need to change your fuel system over for the injection. Convert the engine harness over and then determine whether the alternator P/S pump and such get swapped in. Exhaust manifolds, etc.
That just touches on the work involved.
It is do-able but it is a big job.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6006 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-06-10 07:17:45 UTC
