Flat towing questions #785640 02/02/07 05:31 AM
bnold Offline OP
Hi I'm new to the Toyota world. I've been in the diesel performace world for the past year or so (still am). I just purchased a fairly clean 85 Yoda with 7inches of overall lift.. (Has 3" body that probably wont be staying don't like body lifts much...). As the topic implies what do I need to know as far as flat towing this vehicle? I have read to remove the rear drive shaft and make sure the front hubs are unlocked. I have multiple trailers but the homeowners association is on my butt about having a trailer in the driveway. I'm in college and like to have something to tinker on here and then tow it ho,e to use my shop for larger projects.
Also what do I need to look for in a cheap tow bar? I'm not too worried about it pushing my truck around too much will be using my 3/4 dodge cummins to pull about 8100# dry.
1 specific question that comes to mind is steering?
Thanks
Brian (Toyota newbie)
Re: Flat towing questions [Re: bnold] #785641 02/02/07 06:01 AM
4Crawler Offline
Check out the last Q&A in this Toyota Trails Truck Tech column:
- http://www.4crawler.com/4x4/TLCA_TruckTech/TruckTech.05.03.html
Re: Flat towing questions [Re: 4Crawler] #785642 02/02/07 06:18 AM
bnold Offline OP
So just remove the rear drive shaft and make sure that the front hubs are unlocked. What about the steering? Locked unlocked? What about tow bar selection? Just the cheap A frame type? Thanks Again
Re: Flat towing questions [Re: bnold] #785643 02/02/07 06:25 AM
4Crawler Offline
I got one of these from JC Whitney:
Its about $130.
I've never flat towed mine, so not sure on the steering, but this forum thread says to unlock it.
Re: Flat towing questions [Re: bnold] #785644 02/02/07 09:59 AM
Snowtoy Offline
You will want to leave the key in the ignition in the unlocked position, otherwise you wont be able to turn the truck.
If you are going to do a lot of flat towing, you might want to consider swapping in a full floater rear axle kit with hubs, then just unlock the hubs when you tow it.
Re: Flat towing questions [Re: bnold] #785645 02/03/07 05:52 AM
fourwd1 Offline
I flat tow my Runner frequently, using the same bar in Rogers pic.
Disconnect the rear drive shaft, t-case in 2-HI, tranny in N, hubs unlocked, and steering UNLOCKED.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6125 MB (Peak: 0.6995 MB) Data Comp: Off Server Time: 2026-06-07 06:13:25 UTC
