Front axle nut size #785753 02/02/07 08:07 PM
A
anubis Offline OP
Just what it said. I used the search and it pulled every post with axle front from the archives. Can someone help me out quick so that I can pirchase one before wheeling tommorrow. BTW its a second gen passport/rodeo outer hub nut thanks
2002 Honda Passport. 3 inch Indy4x lift with 912 OME's. 265 75 BFG m/t's with a 3 inch body lift, safari rack, tube sliders, tube rear bumper, on-board air
Re: Front axle nut size [Re: anubis] #785754 02/03/07 01:40 AM
A
anubis Offline OP
Oh for petes sake. 21 people have viewed this and still no response. Come on people someone has to know. Oh well I leave to early to get one this will just have to go on the hope it dont break list <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Front axle nut size [Re: anubis] #785755 02/03/07 03:30 AM
Starchild Offline
For the life of me, I can't figure out what "nut" you are talking about <img src="/forums/images/graemlins/confused.gif" alt="" />
Do mean the bolts that hold the hub cover on? If so, what hubs <img src="/forums/images/graemlins/confused.gif" alt="" />
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: Front axle nut size [Re: Starchild] #785756 02/03/07 04:27 AM
A
anubis Offline OP
shoot you know what The 2002 rodeos and passports and up have whats called a big nut <img src="/forums/images/graemlins/lol.gif" alt="" /> no seriously. I do not have the ability to add manual hubs because of this reason. But in order for me to remove the hub assembly this so called big nut needs to come off. rear pain in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> if you aske me. hence the axle swap.
I just didnt want to get stuck out on the trail without this socket. But at the same time I forgot to realize that this was not a problem on most of the trucks on this forum. sorry. I will take my chances. thanks for the reality check <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Front axle nut size [Re: anubis] #785757 02/03/07 02:19 PM
Starchild Offline
Oh, the "big nut" <img src="/forums/images/graemlins/lol.gif" alt="" />
Hope you don't need to remove that this weekend, because I haven't a clue on the size.
Have fun!
"SERENITY NOW!"
Re: Front axle nut size [Re: anubis] #785758 02/03/07 05:47 PM
throwin_roost Offline
I believe its 29mm.
93 Rodeo 3.2L, 3" body lift, 3" Indy4x lift on 33's, flowmaster50, stainless brakes and clutch lines,
Re: Front axle nut size [Re: throwin_roost] #785759 02/03/07 08:57 PM
Smiley Offline
I believe its 29mm.
I just did a search myself, looking for a photo that someone posted once, but I can't seem to find it anywhere.
Anyway, as I recall, that hub nut is quite a bit bigger than 29mm... after all, that's only 2mm larger than the bolt you turn to crank the T-bars. --- My memory of that photo has me thinking that it's at least in the mid to high 30s, if not larger.
Not much help, I know -- Sorry.
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: Front axle nut size [Re: Smiley] #785760 02/04/07 03:06 AM
JLEMOND Offline
HEY SMILEY I BELIEVE THAT AXLE NUT IS 36 MM , THE TORQUE IS DEFINATELY 245 FT LBS AND HAS A STAKE SPOT ON IT JERRY
Re: Front axle nut size [Re: JLEMOND] #785761 02/04/07 02:48 PM
A
anubis Offline OP
Thanks ill start at 36mm
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6267 MB (Peak: 0.7304 MB) Data Comp: Off Server Time: 2026-05-29 18:51:37 UTC
