Sparkplug heat range #785787 02/02/07 11:20 PM
scogind Offline OP
Will changing to hotter/cooler plugs have as much effect on a 2.4L 4-stroke engine as it does on 2-stroke engines?
Re: Sparkplug heat range [Re: scogind] #785788 02/02/07 11:33 PM
mosk Offline
You shouldn't need to change heat ranges unless you are turbo or supercharging. On my turbo motor, I run plugs that are one range colder than stock. Go too cold and they will foul, go too hot and they'll cause detonation.
-Jeff
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: Sparkplug heat range [Re: mosk] #785789 02/03/07 01:22 AM
J94_4runner Offline
on my '94 3.0 I went 1 step colder. running Bumped timing. They look text book perfect. If I had to pass emissions I'd just throw the stock plugs in for the inspection.
www.celicasupra.com
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.011s) Memory: 0.5927 MB (Peak: 0.6458 MB) Data Comp: Off Server Time: 2026-07-17 02:19:33 UTC
