Sparkplug heat range
#785787
02/02/07 11:20 PM
Will changing to hotter/cooler plugs have as much effect on a 2.4L 4-stroke engine as it does on 2-stroke engines?
Re: Sparkplug heat range
[Re: scogind]
#785788
02/02/07 11:33 PM
You shouldn't need to change heat ranges unless you are turbo or supercharging. On my turbo motor, I run plugs that are one range colder than stock. Go too cold and they will foul, go too hot and they'll cause detonation.
-Jeff
[Re: mosk]
#785789
02/03/07 01:22 AM
on my '94 3.0 I went 1 step colder. running Bumped timing. They look text book perfect. If I had to pass emissions I'd just throw the stock plugs in for the inspection.
94runner: Dana 44 SAS, 35's, Lockers, gears, winch, rock rails, bumpers, 3"BL, drivetrain lift, Budbuilt cross member, centerforce clutch and MORE! ***FOR SALE*** $8,500 -1985 Supra (STOCK!) FOR SALE $4,000 www.celicasupra.com
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.5912 MB (Peak: 0.6443 MB) Data Comp: Off Server Time: 2026-07-15 00:21:18 UTCValid HTML 5 and Valid CSS
