Installing gears myself #786135 02/03/07 10:57 PM
Adam F Offline OP
I ordered up a set of 5.29's from PORC the other day. I'm going to install them myself. (unless someone local wants to help) I plan on re-using the bearings if they check out OK. I ordered up 2 crush sleeves to do the install. I've read through multiple gear installs on the web, and plan on following those closely. I was planning on bringing the pinions to work and swapping pinions since I don't have a press at home, but do at work.
I just don't know how to accurately read the gear pattern using the paint. If I set it up and post a pic of the pattern, could you guys tell me "add a shim" or whatever, and then come back with another pic? I want to get them setup right. Thanks!
97 4R, stock, daily driver
Re: Installing gears myself [Re: Adam F] #786136 02/04/07 12:33 AM
elripster Offline
Sure. What I remember from doing this is that I needed to shim the pinion more than once to get it right so you might acually just do the set up at entirely at work. You have to have it all assembled to check the pattern and will have to re-shim if it is off.
The pattern needs to be centered on the teeth like in the pictures. I can't remember if biased outwards means moving the pinion deeper or shallower of if that is affected by the backlash though. I'm sure you can find that out somewhere or else you'll know real quick when you shim it and it moves accordingly.
Good luck!
Frank
1994 4runner, 3.0, auto, 4.88's, 31's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos.
www.sdori.com
Re: Installing gears myself [Re: elripster] #786137 02/04/07 01:25 AM
4x4runner Offline
I am sure Zuk will help with the pattern check. I was under the impression the solid sleeves were better than the crush sleeve?
Re: Installing gears myself [Re: 4x4runner] #786138 02/04/07 01:32 AM
Adam F Offline OP
I've heard of people preferring both, so for simplicity I chose the crush.
Re: Installing gears myself [Re: Adam F] #786139 02/04/07 04:46 AM
ZUK Offline
Let the pics role... <img src="/forums/images/graemlins/cheers.gif" alt="" />
mostly stock
Re: Installing gears myself [Re: Adam F] #786140 02/06/07 11:23 PM
Shannons_v8toy Offline
hello i have some personal experiece on this one i installed detroit easy lockers in my 84 toy and had 4.11 gears lockers and abuse ..lol destroid the crush sleaves due to added stress on pinion gears p.s. 35 inch tires then i installed 4.88 gears and lockers in with crush sleave eliminator kits and have pulled checked diff.s pattern is still perfect after 3 years pinion is good and still tight not like prior crush sleaves and have broke 3 berfields and partialy stripped det locker but gear and pinion are fine due to the strength of the crush sleave eliminator kits check it out for your self hope this help need more hit me us GOOD LUCK IT'S NOT EASY took me two weeks for first diff and tree days for second same situation as you got try allprooffroad.com they got the stuff !!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Shannon 84 toy 7"lift 35"tires 4.88gears det. lockers 320hp smallblock chevy th350 auto trans on baurd air snorkle on baurd welder 8000lb winch custom rear bumber nerf bars
Re: Installing gears myself [Re: Shannons_v8toy] #786141 02/07/07 03:06 AM
Adam F Offline OP
I ordered Yukon's from PORC. Got them today. Just wanted to know what the numbers meant on the side...I know Yukon's can be any number of gears....here's the numbers
Pinion
YG-TV6-529 337 2.460
Ring
337 A6 Yg-TV6-529 304
What's that all mean? Did I get a good gear?
Re: Installing gears myself [Re: Adam F] #786142 02/07/07 03:28 AM
ZUK Offline
the 304 at the end means it's a nice gear. <img src="/forums/images/graemlins/kewl.gif" alt="" />
mostly stock
Re: Installing gears myself [Re: ZUK] #786143 02/07/07 03:30 AM
Adam F Offline OP
Excellent! Thanks! Just hope I don't screw things up! <img src="/forums/images/graemlins/drunk.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Installing gears myself [Re: Adam F] #786144 02/07/07 03:42 AM
Pinion
Ring
CHECK ME see if i'm right just guessing you ordered 5.29 gears most is part # plus part spec.s yg-tv6-529 is pinion 6 teeth on pinion matched to set 529=5.29 ring gear 2.460 rotation of pinion for 1 rotation of ring gear ??
and so on with ring gear #'s think hard to say how manufacturer doe's it they are all differant ..
yukons are supposed to be good did u pay alot usually u get what u pay for i payed cheap $300. per set 4.88 gear from seirra western or something i dont remember they sound good put crush sleeve eliminators in from allproofroad.com
peace shannon
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6438 MB (Peak: 0.7639 MB) Data Comp: Off Server Time: 2026-06-17 10:40:34 UTC
