PS pulley Removal help.
#786235
02/04/07 01:14 AM
How do I get this dang thing off? I have a 1990 V6 4runner and Im rebuilding the power steering pump and cant get the pulley off. Any tricks, right now I have it soaking in some WD40. Ive pryed from the back making sure not too bend the pulley and cant get it off. It probablly be a piece of cake with a Pully puller hu??
1990 4x4 4runner 3.0L V6 the mystical two Door unibody
Re: PS pulley Removal help.
[Re: Adam F]
#786237
02/04/07 10:28 PM
but I dont see how that would pull a PS pulley.. there are no other holes for screwing in any bolts in the PS pulley? Unless that kit comes with jaws, and your pulling on the outer part of pulley (which I dont know if thats a good Idea or not).
Also the pullers at any automotive parts store have PS pulleys that wont work either b/c they are pulling on a lip on the inside of pulleys, which Toyotas dont have.
[Re: 90twodoorrunner]
#786238
02/06/07 06:59 AM
Well, I got it. It took 2 pry bars on either side of the pulley and all 215 lbs of my weight. That woudruf key was frozen on there. I also learned a few things. 1. the rebuild kit from Napa. has 1 extra oring and a unused clip and 2. its missing 1 of the proper size o-rings for the inside diameter of the 3rd inner plate.
#786239
02/06/07 11:13 PM
next time just use the ps puller...hope you didnt bend the pulley
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
[Re: willzrunna96]
#786240
02/07/07 04:26 PM
I could not find one anywhere that would work on my PS pulley? Do you have a pic of one, or know where to buy one?
#786241
02/07/07 10:40 PM
i just used the rental at autozone
[Re: willzrunna96]
#786242
02/08/07 02:40 AM
what year is your truck/runner. B/c the ones they had at autozone would not work for my 90 runner. Unless you used a universal puller with the large Jaw like things.
#786243
02/08/07 05:20 AM
no i used a regular ps puller that grabs it from the flare in the middle of the pulley
[Re: willzrunna96]
#786244
02/11/07 12:14 AM
hu well that explains why you got yours and I had to pry mine, Mine does not have a flare in the middle. so what year is yours? my runner 90 and no flare as I said, there for I pryed it off, with no damage/bending of the pulley.
